Summary of problems reported on Prius 2010
Discussion in 'Gen 3 Prius Main Forum' started by CivicQc, Aug 15, 2009.
  1. CivicQc
    CivicQc The world needs more prius
    233
    99
    Planet Carbon
    Yes, that's a good idea...
  2. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    For all you up in early snowland (Canada, the Rockies, etc.), any reports of problems with the traction control system on snow/ice, especially going up hills? Heard about it on Gen II, and wondering if they've fixed it.
  3. CivicQc
    233
    99
    Planet Carbon
  4. Hippie
    Hippie New Member
    San Francisco
    I put burn holes in my brand new seats. I park my fat keister in them and now they look shabby! Oh well, I'm going to snag some zebra seat covers so I can ash up some "herb" roaches on the seat. DY-NO-MITE! :rockon:
  5. RoyThePriusGuy
    RoyThePriusGuy New Member
    186
    25
    phoenix
    This is a Prius problem? Please spare us from your personal habits. This type of input better fits your facebook page...
  6. kgall
    kgall Active Member
    984
    152
    Given the thread on discharge of the 12 volt battery in 10+ days, I'd include that as a problem Toyota's engineers ought to pay attention to.
  7. blisspacket
    blisspacket Junior Member
    32
    StAugustine FL
    As a preventive maintenance freak, I often check the oil. I thought I wasn't doing something right in sliding the dipstick back because it required a stronger push, and it felt like I was galling the dipstick tube. Today, when I encountered the same resistance, I examined the dipstick end. It had a rough unfinished taper to it. Wiping my finger over it got a silver tarnish to my finger. Clearly there HAD been galling. Anyway, I put the dipstick under the buffing wheel, and now it slides down just pretty slick. This is an easy fix that, if true to all the 2010"s, should be cured.
  8. CivicQc
    233
    99
    Planet Carbon
    Thanks, kgall, for bringing this up.
    I have read the thread entitled http://priuschat.com/forums/gen-iii...-will-park-lax-13-days-dead-battery-sure.html (that is probably the one you are refering to). It appears there is some debate as to whether this is actually a problem, though (unless you can convince me otherwise). I prefer not adding it to the list until it is settled.
  9. kgall
    kgall Active Member
    984
    152
    Thanks to you too CivicQc. The thread you cite was one that I looked at. But I was a bit more bothered by the following thread:
    [​IMG] 2010 II 12 Volt Battery Dead After 17 Days of Parking ([​IMG] 1 2 3 ... Last Page)
    [email protected]
    (I'm not sure if the link will work, but it's on the first few pages of the list of Gen III main forum threads, and you can go to it there)
  10. marcovi
    marcovi Junior Member
    31
    Hi Guys,
    Subject: Inside Cabin overhead lights.
    I have found another annoying problem. In previous generation you could actually tell when the cabin overhead lights were turned on when you turned off your car.
    Now, there is no way in knowing if you left the interior light ON when you leave.
    You have to wait for the main headlights to go off or wait for the timer to turn off light cabin overhead lights to see if you left it on. Its annoying..
    Before you could notice it by the difference in brightness.
    I have Prius V white pearl.
    Any input?
  11. TracyJ
    TracyJ Junior Member
    39
    Atlanta, GA
    I'm also having an issue, all of a sudden, with the interior overhead light. It's set on "door" and had been working beautifully.... came on when I got close to the car, stayed on when I opened it and went off on cue when I shut the door. The other night I needed the light on while I was in the car(at the drive-in) so I toggled it to "on" and then back to "door" when I was done. Now it won't come on. When I approach the car, nothing. When I open the door, nothing. It's still set on "door" and will come on if I toggle the switch to "on", but won't work at all in the "door" position anymore.:confused:
    Any ideas?
    Thanks, Tracy
    Update: I found out there's a toggle switch controlling all the interior lights right above the Safety Connect button. It was in the off position. Switched it on and Wha-Lah! I'm glad it was even simpler than I thought it might be.
  12. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    Make sure you didn't leave it in the OFF position by mistake, flip the switch back and forth a few times to make sure the contacts are closing properly. That's about all you can do, if that doesn't fix it take it to the dealer. It's a fairly simple problem so they should be able to fix it with no problems.
  13. Milo'sPrius
    Milo'sPrius Milo'sPrius
    Massachusetts
  14. CivicQc
    233
    99
    Planet Carbon
    blisspacket,
    Thanks for the info.
    If you can find (or start) a thread that describes the problem, and that shows that other people have experienced the problem too, etc. (see the rules in post #2), post the information on this thread then I will add it to the list.
  15. kawasugi
    kawasugi New Member
    los angeles
    Momentary loss of braking power when navigating over a bumpy surface of pot hole
    Gen 3, 2010 Prius Build Date May 2009
  16. kawasugi
    kawasugi New Member
    los angeles
    Delay in answering calls with Nav and Bluetooth
    2010 Prius Gen 3, Build Date May 2009
  17. Orf
    Orf New Member
    414
    Devonport, Tasmania
    What is a Safety Connect button and where is it?
  18. georgekessel
    georgekessel Member
    182
    I have a Black Prius 5 (just took delivery) and noticed that the bumpers are not the same color as the rest of the car. Today is the first time I've washed it and just noticed this.:confused:
    I didn't notice this listed - anyone else have this issue?
  19. eldiee
    eldiee Member
    118
    17
    Iowa on Mississippi River Bluffs
    I had the same experence as several others with momentary loss of braking on a rough road yesterday. It seems that it(rough road) cancels regenertive braking action. It surprises you when it happens.
  20. Ohpoh
    Ohpoh Junior Member
    Los Angeles
    im glad im not the only one having this problem. Whenever i go on bumpy road or bumps while im slowing down, the car seems like its accelerating or the engine is kicking in. I get alittle scared that if i dont brake hard, im going to hit the car in front of me.
