GRRRRRRRRRRinding going into reverse..
Discussion in 'Gen 3 Prius Technical Discussion' started by Gasitman, Oct 20, 2009.
  1. Gasitman
    Gasitman New Member
    118
    Washington
    I went to grab a bite to eat and realized the line was far to long so I hopped back into the car, I heard a huge grinding sound when I went to put the car into reverse. I was like Wth is that? :eek:
    I looked around to see if any machinery was around and I saw nothing. I wanted to rule out it was not my car. This ever happen to anyone else? Or maybe I did hear something that was not my car, please tell me it was not my car. :(
  2. RadioZero
    RadioZero Member
    154
    59
    Orlando
    2018 Prius
    you say you hopped back in the car. was the car moving at all when you put it in reverse?
  3. Fstr911
    Fstr911 Member
    235
    55
    That guy standing behind you with the "Will work for food sign"; was he still standing behind you?
  4. richard schumacher
    7,664
    1,046
    United States
    Sticky parking brake? Or, if you were on a slope and didn't use the parking brake, the parking pawl can sometimes make a noise when disengaging. You probably already know that the transmission gears are always fully meshed, so you did not hear the grinding of gear teeth.
  5. Gasitman
    Gasitman New Member
    118
    Washington
    I was on a hill, and I was out of the car for about 30 seconds, so I would say it was not moving. I hope no damage was done.
  6. Tideland Prius
    16,598
    Did the sound happen when you were releasing the brake pedal to creep down the hill?
  7. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    Maybe it was the reverse chime - telling you it was weary and tired of always being called upon when the car is placed in reverse;)
  8. Gasitman
    Gasitman New Member
    118
    Washington
    LOL, not sure, but if it happens again, I'm going to the dealer.
  9. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    You ARE aware that there is no reverse gear, right? Reverse just uses the electric motor (MG2) in reverse. Now if you have mudflaps, and they were over a curb, that can cause a loud noise as they are dragged across the curb. It's quiet when they are dragged onto the curb.
  10. Gasitman
    Gasitman New Member
    118
    Washington
    No mud flaps, and no, no idea how the thing works honestly. However today, I put the car in reverse, had my foot on the brake and the brakes swelled and stopped the car, kinda like not having brakes, then having them superfast. I am wondering if I am putting the car into reverse to fast after starting the car. I would not think so, but something is not right. Going to the dealer in the morning, maybe I need to be retrained on how to drive this thing. Far cry from a minivan.
  11. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    This is a known problem for some people. See this thread -
    http://priuschat.com/forums/gen-iii-2010-prius-main-forum/65875-braking-in-reverse.html
  12. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    IMO I would think it's more of a learning curve with the new vehicle. Nothing bad meant by that comment for sure. Just a learning curve.
    Since it does not have a transmission pursae, you don't feel things the same way with the MG's etc.;)
  13. Gasitman
    Gasitman New Member
    118
    Washington
  14. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    I'm crossing my fingers and going with a stick stuck into something under the car or something similar, maybe ran over something plastic like and drug it a short distance maybe etc.
  15. Gasitman
    Gasitman New Member
    118
    Washington
    I had to cancel the appointment with the dealer, had to do something else. Going in on Tuesday. I have not heard anything, but I did have the brakes swell on me again.
