How to maximise cooling effectiveness on hot day???
Discussion in 'Gen 3 Prius Main Forum' started by ozboy, Oct 27, 2009.
  1. ozboy
    ozboy New Member
    Australia
    Correct me if I'm wrong, but if you have a solar roof panel, it is better to park it in direct sunlight than in the shade, on a hot day???
  2. patsparks
    10,664
    569
    Adelaide South Australia
    I would think it is still better to park out of the sun. If you stop the surfaces heating up then you don't need to try to remove the heat with a fan. It is also better for your paint and upholstery.
  3. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    I would agree with Pat. It would be best to avoid the sun where possible. More than just keep the car cooler, it would reduce UV wear.
    Failing that, it's best to have uninterrupted sunlight on the solar panels. If you haven't yet, park your car in the sunlight and turn on the A/C. Use your hand to shade any part of the solar panel and watch the A/C shut off. It's easier to observe if you tape a piece of tissue paper to the vent. You will find that any interference with the panel shuts off the A/C.
    For this reason you are correct. Parking in direct sunlight is the best way. Personally, I would also crack the windows a bit.
  4. GreenGuy33
    GreenGuy33 Active Member
    534
    29
    Rhode Island
    I agree. It is better to keep the car out of the sun and keep it cool naturally, rather than relying on the solar cooling system.
  5. Jayhawker
    Jayhawker New Member
    52
    AZ
    You definitely want to park in the shade. The temp of a parking lot here in the summer can reach 140 + degrees. I am wondering if it's pulling that hot air through the car to cool it???
    I am very lucky to have a parking garage here at work.
  6. GreenGuy33
    534
    29
    Rhode Island
    Yes, from what I have seen, it just moves the hot air around. It doesn't provide any actual "air conditioning".
  7. Tideland Prius
    16,660
    It vents out the hot air so that it doesn't build up inside the car.
    OZ, I'd park in the shade if you have the option. It'll reduce the wear on your interior due to the UV and other sun effects.
  8. xbdude
    xbdude opticat
    168
    North Central Florida
    Park in the shade and get the bird crap, sap, leaves, caterpillars, and all the nasty stuff that can fall from trees (I'm in Florida and there IS nasty stuff that falls from trees). Or park in the sun and let the UV deteriorate the rubber, plastic, and paint. Ah, what difference does it make in the end? We're probably all going to trade our 2010s in for a plug-in in a few years anyway!
  9. Manolo1
    Manolo1 New Member
    150
    South Florida
    All official temps are shade temps so in a 90 degree day your car will be 90 degrees inside if left in the shade, and probably just 110 in the sun (other non-sun-roof cars will be 120+) ...
    so shade is always your best bet! :mod: :cool:
  10. paulemus
    paulemus New Member
    93
    San Diego
    I believe solar panels, at least the one's on my house, still generate voltage in the shade.
    Here's a little trick if you want to leave your dog in the car: Leave the car vehicle power on, lights off, air conditioning running. Roll down driver's window. Get out and close door. Reach in and lock locks. Flip the window switch to roll up while quickly removing your arm. The vehicle is locked and A/C is running on battery most of the time. Then use your hard key slid out from key fob to open the door when you want to get back in.
  11. TonyPSchaefer
    14,816
    2,501
    66
    At a Chicago Prius Group meeting, we were all stunned when we found that placing your hand on the solar array shut the entire thing off. It's as though they are all wired in series such that when one stops producing electricity they all stop.
    Please note that I'm only talking about the Prius panels here; I'm not addressing any other PV technology.
  12. Joe166
    Joe166 New Member
    720
    97
    South Florida
    That's great, but I bet it is just a matter of time (and not much time) before someone sees your dog in a closed car with the windows shut and no motor running and you come back to a bashed in window and a starring role on Animal Police on the Animal Planet Channel.
    Cute parlor trick, but doesn't sound too practical to me. Besides, Henry (my Field Spaniel) would be so angry at being left behind he probably would never speak to me again.
  13. AussieDave
    AussieDave New Member
    Melbourne Australia
    In Oz we get the solar panels with the moonroof. I have gotten in the habit of leaving the moonroof open to the first stop and the heated air rises out through it.
    Then approaching the car I hit the remote aircon to get that last bit of cooling if it is really hot.
    If I have had to park in the sun then the combination of moonroof and solar powered fan really does quite a good job.
    David
  14. ozboy
    ozboy New Member
    Australia
    :p:p:p
    Very clever!!
