2009 Chevy Malibu vs. a 1956 Chevy Bel Air crash test
Discussion in 'Other Cars' started by cwerdna, Sep 18, 2009.
  1. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
  2. patsparks
    10,664
    567
    Adelaide South Australia
    They sure don't make em like they used to hey?
    Thank goodness for that!
  3. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    It is worth noting that the modern car never even breaks the windshield, whereas the 50 year old one loses cabin integrity back to the B pillar.
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Gotta love the fuzzy dice on the rear-view mirror in the Belair! BTW, I'll take the Malibu, thanks.
  5. dogfriend
    7,512
    1,189
    Carmichael, CA
    At least you wouldn't have to cut the body out of the Bel Air. :madgrin:
  6. ualdriver
    ualdriver Member
    358
    64
    Midwest US
    There were some comments below the video that stated that the Bel Air didn't have its engine installed. I wonder how that would affect the results to the Bel Air, good or bad?
  7. hill
    8,732
    Sadly, according to the other thread here, you'll have to take your Malibu with just ICE propulsion ... as GM pulled production of the hybrid version.
  8. patsparks
    10,664
    567
    I think you would, unless you buried the person still in the car.
    The body shell of the Bel Air was distorted in the rear quarter panel if you watch closely.
    Very bad, and without legislation this would be the standard of cars on the road today.
  9. dogfriend
    7,512
    1,189
    Carmichael, CA
    If you look at the first slow motion sequence, you can clearly see the exhaust tubing under the engine and then you can see the whole exhaust system is ripped backwards under the car as the collision occurs. I submit that this would not happen if the engine wasn't attached to said exhaust system.
    BTW, I think it was common on older vehicles to have the engine intrude into the passenger compartment during collisions. I believe that is why you see the whole dashboard pushed back into the front seat area during the collision. Part of the design improvement(s) of newer cars is to make sure that the engine does not intrude into the passenger compartment.
  10. patsparks
    10,664
    567
    If this were the case the front suspension would be at full height. I don't believe the engine has been removed, and even if it had the rubber engine mounts would do nothing to restrain the engine.
  11. dogfriend
    7,512
    1,189
    Carmichael, CA
    I think you could just pull the door off its hinges, therefore no need to cut it off. You might have to dismantle the interior though to get all the extra (human) body parts. :madgrin:
  12. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
  13. hyo silver
    hyo silver Awaaaaay
    15,268
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Did you read the part in that article about how the Malibu did a good job at "keeping the occupant compartment in tact"? (italics mine)
    Depends on the occupants, I'd say. ;)
  14. fuzzy1
    10,337
    I had understood that they stopped hybrid production because they had enough unsold inventory to carry them through much of the next model year. So you should still be able to get a brand new Malibu Hybrid. Maybe even with a very steep discount, especially if you do the scrubbing to get all the grime, tree sap, and bird dropping off one of these lot queens.
  15. F8L
    19,011
    4,083
    Grass Valley, CA.
    God that was straight ugly. :eek:
  16. Tideland Prius
    16,505
    <shudder>. Thank goodness for modern crash structures.
