Should my Hyb. batteries be dead at 68,000mi?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Floyd, Oct 28, 2009.
  1. Floyd
    Floyd New Member
    Gulf Coast, Grand Bay, Alabama
    The unthinkable happened to me. I got the red triangle, check engine, and the pink hybrid system warning light on my mid along with a loud fan sound from the rear seat. None of the warnings were blinking and the car seemed to run normal.
    I first checked all the coolant levels, opened the inverter cooling reservoir and there appeared to be a little turbulence indicating to me that the pump was running.
    The next morning, I started driving to the dealer thinking I could make it. I was watching my screen and the batteries seemed to be charging but was acting strange. Suddenly, no charging at all and the car started slowing down and seemed to rev up as if in passing gear and the battery charge indication slowly went to one bar.
    I stopped before the batteries discharged completely and called the towing folks. The dealer serv. manager said that there were conflicting codes and it appeared that the Hyb. batteries were bad and was waiting advice from Toyota before going any further.
    Isn't it very unusual for the hyb. batteries to go out at 68,000mi? Also, why wouldn't the screen show any kind of charge going to the batteries? On a regular car, even if the battery is bad, the alt will still charge; but I understand the Prius is a different animal all to gether. I also have and extended warranty if I should need it. Any one have any other idea what might be wrong? Has anyone had a similar situation to this?
  2. MJFrog
    MJFrog Active Member
    780
    267
    NE Oklahoma
    2018 Nissan LEAF
    Not to be Johhny-one-note, but have the 12v battery checked/changed first. MANY weird and off-the-wall error conditions have been reported when the 12v aux battery starts to go.
  3. Patrick Wong
    18,200
    6,500
    Yes, it is unusual. I would not expect a 12V battery problem to cause the symptoms that you noted.
    It's likely that you have at least one bad module in your traction battery. Since the traction battery ECU can detect a failure, it probably stops charging to avoid a safety issue. If a module has failed, it may not be able to accept charging current without overheating & possibly blowing up.
    The traction battery is covered to at least 100K miles under the manufacturer's warranty so you should not need the extended warranty coverage.
  4. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
  5. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
  6. Floyd
    Floyd New Member
    Update: The service manager ordered a Hyb. battery and installed which he said was the problem. I also decided to get a new 12v battery installed even though he said that it wasn't needed. The Prius is a 05 which makes the battery over 4yrs old so I didn't want to take the chance of getting stranded again. I've also got second thoughts about getting another Prius come trade in time even though I love the car. I've been driving cars for many years and the Prius is the first car that has gotten me stranded. Thanks
  7. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    Glad to hear that you were able to get it resolved, Floyd.
    Would you mind giving us some more details. Simple things like how long did the process take? Did you drop the car off and leave or did you wait?
  8. Bica2go
    Bica2go New Member
    321
    57
    Boston, MA
    Floyd, I appreciate that this was an unfortunate episode, but I wouldn't write off getting another Prius because of it. First, from what I can tell, it's very unusual for the Hyb battery to go so early and fortunately it's covered under warranty. The Prius continues to rank high in reliability (per Consumer Reports).
    Secondly, I've lost track of the number of cars of various makes and models that have left me stranded over the years. My favorite was a Saab losing power on a bridge heading into Boston at 12:30AM. To my amazement, a taxi passing by stopped and offered to push me to a nearby off ramp so I could coast into a gas station at the bottom, then took me home. This happened in the days before cell phones were common - I could have been up on that bridge for a long time! Then there was the timing chain that went on a 2yr old Ford, in the Scottish countryside, while I was on my honeymoon. There's a reason so many people have AAA.
  9. Celtic Blue
    2,224
    139
    Midwest
    Floyd,
    This is more a matter of perspective: You won the hybrid lotto! Unlike most owners, you have a brand new hybrid battery, paid for at Toyota's expense in a 4 year old car that is otherwise approaching the end of the hybrid warranty (32,000 miles left to go.) About the only thing better would be having it go at 99,999 miles and 7 years + 364 days (non-CA warranty.) The worst case is having a battery fail at 100,001 miles or 8 years + 1 day.
    Yes, it dents your confidence in the reliability of the car but assuming there isn't a nasty gremlin in this particular sample of the vehicle you are set. Toyota warrants the original batteries for 100,000 miles so another short life failure would be highly unusual.
  10. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    well Floyd, sorry to hear you feel that way. but dont worry, there are a dozen people in line behind you waiting for your car.
    now, i dont have a lot of experience driving Pri's compared to other types of cars and none with the mileage you have on yours, but in 5½ years, i have never had an issue of any kind with the Pri (other than flat tires and TPMS warned me the tire was low so i could air it up before any issues arose)
    i cannot say that for Chrysler, GM, Datsun (Nissan if u will) AMC or BMW... but take them off the list and there are still plenty of choices out there.
    so, how much that repair cost?? how long it take? were you given a loaner to drive while waiting?
  11. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Personally I won't mind another short life failure right at 99,999 miles and 7 years + 364 days. :D
  12. Floyd
    Floyd New Member
    2nd update: I apologize; I'll probably trade for another Prius in 2011. Really, I wouldn't take a gold monkey for my car.
    Luckily, I have another car that I use as standby. The dealer kept the car a week mainly because they had to get the battery shipped, plus, one day the Prius tech. had to go to school.
    While in the shop, I got a new 12v battery installed. With the new Hyb battery, I seem to be getting better mileage. Before, I was getting 44 to 45mpg. Now my screen indication is around 50mpg. I can get into the ev mode easily whereas before, it was a real effort. I'm just wondering if the old battery was maybe defective from the get-go or was never quite up to par, maybe a weak cell that prevented top performance. (no doubt, going bad at 68,000mi)
    Now, it seems like a different car and I'm a happy camper. Thanks for all the replies.
  13. ggcc
    ggcc Member
    132
    Bay Area, CA
    2014 Prius Plug-in
    Floyd,
    How do you get to EV mode? Do you install EV switch on your Prius?
  14. Floyd
    Floyd New Member
    I may not have the right terminology. EV mode to me is when I can drive under battery power only. Usually lightly accelerate from a stop or coasting (when the engine cuts off) and under 39mph. I haven't noticed how many charge bars I have when I do this but the new traction battery seems to retain a charge better therefore making it easier to go under battery power only. Usually, I can't go very far this way only about a mile. I think some others on the forum have gone further.
    I haven't installed the EV switch mainly because of my wife. Bless her heart, she may leave it on accidentally, and u know the rest of the story.
    Bottom line: I'm sure there has been several Prius's that came off the production with a defect in the traction battery (Hyb. battery) whether a weak cell or what ever, that would cause sub-par performance.
  15. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    Floyd;
    thanks for the update. very interesting the change in MPG's being so dramatic. did you by chance track each tank's performance??
    if so, i strongly suggest you starting a thread showing the mileage performance before and after the battery change. might be of interest to the many people here who are not getting the mileage they had hoped for
  16. Celtic Blue
    2,224
    139
    Midwest
    Yes, this could be a key point for some: What happens if the hybrid battery is "weak" from the outset? Does mpg suffer noticeably?
    It makes sense that if the original battery was marginal (e.g. a weak cell or two), the pack would fail sooner. What is not as clear is how this might impact overall gas mileage.
  17. Floyd
    Floyd New Member
    Driving for a while after the Hyb battery replacement, I have noticed an increase on the MFD only and haven't refueled enough yet to get consistent tank mileage but will post another link later after I have cycled thorough a few tanks.
    I talked to the service rep and asked if they did anything besides just replacing the Hyb battery & he said that was all they did. The mpg increase may just be unusual but around 50mpg is the overall average of interstate travel about 20miles each way that I'm getting now. Before, it was between 43 and 46. As a matter of fact, we took a round trip of 600 miles the day before the battery went belly up and the last tank averaged only 38mpg. I thought something was unusual and passed it off as an uncomplete fuel top off the tank before the last one.
    U know how it is when filling and different gas stations, its a little inconsistent. Looking back, I attributed the low mileage to the engine constantly having to recharge the battery. I may be all wrong, but it's looking that way. I'll get back later to post my findings. Thanks
  18. drees
    drees Senior Member
    1,782
    247
    Right on - with a weak battery that rapidly loses charge, the Prius isn't able to use the battery's stored energy under certain conditions (gentle starts, cruising at low speeds) to improve fuel economy and as a result the engine ends up running more.
