Parking assist
Discussion in 'Gen 3 Prius Main Forum' started by thanasi, Nov 3, 2009.
  1. thanasi
    thanasi New Member
    Vancouver BC
    I'm looking at buying a Prius with IPA but my wife took one for a test drive and did not like the feature. She felt like the time it took to setup the IPA would make her nervous on a busy street when there are cars waiting behind you.
    So, I'm wondering if anyone who has this feature actually uses it in real world situations? Does it get easier to use after a while? Any real feedback would be very much appreciated.
    Cheers,
    T
  2. qbee42
    3,080
    Most people consider it a novelty. It's fun for impressing your friends, but not all that useful in everyday life.
  3. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    I forget if Canada gets the full AT package. Nobody seriously uses IPA, but precollision system (PCS) and ACC (adaptive cruise control) are great. Most people also like the lane keep warnings and assist (LKW & LKA).
  4. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Just had to post this. :D
    2 people like this.
  5. creativeguy
    creativeguy Member
    301
    17
    CA
    Haven't tried my IPA yet, but I never would have bought it as a stand alone option. I have it only because it is bundled with the other safety options. It is just a bonus because the radar, camera, and steering assist is already present for DRCC and LKA. The rest is just software so why not bundle it.
  6. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    LOL, this is exactly what happened when a group of us Houston priuschatters tried this with my car. The parallel parking went much better, but is still slower than a human driver and more trouble than it's worth.
  7. John-W
    John-W New Member
    I occasionally use it if there is no traffic around. It does take way longer than parking it yourself and if you can't do just as good a job of parking without it I wonder how you got a driver's license. Like others have said, it is a toy. Don't make it your make or break feature. And, as the video above says, it doesn't work uphill. If you touch the gas it cancels itself.
    Canada does get this feature and most of the others. The only one we don't get is the Lane Keep Assist (as far as I can tell). I use the radar cruise all the time. It's great.
  8. Indyking
    Indyking Happy Hyundai owner...
    1,280
    I don't know... Indy, Chicago, Madison (WI)... it
    IPA is a crock of baloney. Sensors in the front and back that warn you when you are too close to an object makes more sense and can actually help you park.
  9. NovaStu
    NovaStu New Member
    102
    Fairfax, VA
    As others have said, it's great for impressing your friends. However, keep in mind that it can only park your car if it can get from the street into the parking space in one "swoop". If you have no trouble rocking yourself into a tight parking space, you'll find this to be absolutely useless in real life.
    Stu
  10. nparker13
    nparker13 Member
    121
    CT
    I disagree, sure its a little slow, but to be honest, I use it a lot.
    If you do it often enough you learn what setup the car tends to recognize well, and it works great. It puts a smile on my face when I do it too.
  11. IraS
    IraS Member
    165
    Austin, TX
    I have tried the IPA and found it to be something to impress people (i.e. "see how the car can park itself") when demonstrating the features of the car.
    Living here in Austin, I have very few opportunities to parallel park. When I park in a parking lot (i.e. perpendicular parking), I pull in forwards - I rarely need to back in. The few times I needed to back in I would have loved to have the IPA to guide me, but that was when I had the 2004 Prius.
    I am not sure I would want to use it to parallel park on a busy street. It might be useful in a residential neighborhood where there is little traffic.
  12. Cassandra
    Cassandra ELECTRIC VEHICLE
    57
    Victoria, Canada
    I don't ever use it because it takes too long.
  13. creativeguy
    creativeguy Member
    301
    17
    CA
    I'd bet that you could parallel park a Prius in many perpendicular spots in the midwest. All the parking lots are designed for gigantic american trucks and SUVs.
  14. Tideland Prius
    16,621
    Depends. The Pre-Support function helps immensely as it can better identify the spot and thus requiring no adjustments. Just look, verify it's ok then press OK. The problem is that you need to understand how the system works (it has a whole section on its own in the navigation manual.. most are standard stuff but there are good tips on how to position and drive the car so that the computer can best park the car for you).
    Have I used it in real life, yes. Did I really need to? No. Most of the times that I've done it is when the parking lot traffic is light. Also if I'm feeling lazy when I come home after work, I'll let the car park for me. Otherwise, I can park quite well and quite quickly (both reverse and parallel park) so it's more of a novelty for me and a gadget for friends and family.
  15. hitechboy
    hitechboy New Member
    128
    Toronto, Canada
    I use it all the time. The success of it depend a lot on the lighting condition of the parking space. When park out door, its mostly waste of time. When park indoor, its work 90%.
    I always let it move into the opening of the spot and finish the job manually if need. Save me a lot of neck turning.
