What was I seeing???
Discussion in 'Gen 3 Prius Audio and Electronics' started by bighouse, Nov 5, 2009.
  1. bighouse
    bighouse Active Member
    822
    126
    Guerneville, CA
    Yesterday when I went to start my G3, on the far left of the instrument cluster I saw, very briefly, a LARGE yellow image of some sort, essentially right where the "safety belt" icon is at. It went away so fast that I did not have a chance to see it and am not really sure what it was- does anyone know what it may have been? It was mostly rectangular and about 1" wide x 1.5" tall...it dwarfed the safety belt red icon.
    I looked through the Owner's manual, but didn't really see anything in there.
  2. Spectra
    Spectra Amphi-Prius
    3,123
    17
    S NJ
    In the Gen-2, a yellow hazard light with a something like a snowflake image, briefly flashes on when the outside temp drops to 37-F. It's meant as a warning that the roads may be slick.
    I'm guessing that this is the light you're referring to.
    A harbinger of fall weather...
  3. jim256
    jim256 Member
    317
    69
    Eastern NC
    The yellow triangle there is the "Master Warning" and there should be a companion alert in text on the MFD, if it's a persistent fault and not simply the check instrument bulbs/warnings portion of the start routine. That's probably what you're seeing. Section 5.02 in the manual.
  4. garygid
    garygid Senior Member - Blizzard Pearl
    379
    Orange County, CA
    They said "rectangular" and BIG.
    The "Hill-Holder" icon is there, yellow, and rectangular, but "small".
  5. Tideland Prius
    16,623
    well at the corner of the eye, it could be bigger than it really is. Seems like the location is indeed the "Slip Indicator"
  6. bighouse
    822
    126
    Guerneville, CA
    yes- it was the slip thing
