replace battery or buy new car?
Discussion in 'Generation 1 Prius Discussion' started by Chipawa, Nov 6, 2009.
  1. Chipawa
    Chipawa New Member
    Maryland
    2001 Prius
    The battery on my 2001 Prius just died. Car has 130,000 miles, and is otherwise in good condition. Now I have to decide whether to replace the battery and get some more life out of her, replace the battery and sell, or just buy a nice new Gen III Prius. Dealer quoted $4400 for a replacement - seems high.
    Any advice?
  2. spinkao
    spinkao New Member
    316
    78
    Czech Republic, EU
    You could probably get a salvage battery much cheaper that that. Changing it yourself is not so difficult either if you are a little DIY inclined, or you can get a mechanic to do it for you. So if the vehicle is in good shape otherwise and only the battery is dead, I would definitely attempt to replace it whether you decide to sell it or not.
  3. bwilson4web
    16,204
    In engineering, we make choices between good, fast, and cheap, pick two:
    • $4.4k - covers labor new battery and disposal of old
    • ~$3k - buy the new battery and do your own labor and disposal
    • ~$2k - buy two NHW20 battery packs, rebuild using new modules, and your own labor and disposal of old modules
    • ~$1k - buy used NHW11 battery (no warranty) and your own labor and disposal
    Your profile does not indicate the area of the country. There are a few independent shops that might give a lower cost than the $4.4k.
  4. philobeddoe
    philobeddoe ΜΟΛΩΝ ΛΑΒΕ
    575
    107
    Los Angeles
    +1 ... good fast or cheap, choose two is a tenet of my industry as well
    from Bob's choices however, it appears you can achieve all three
    i don't know what a 2001 Prius is worth, but if your car is in good shape and well maintained, i'd find the most cost effective and efficient means of replacing that battery, and drive that car another 50-100k :thumb:
  5. philobeddoe
    575
    107
    Los Angeles
    there are a number of replacement batteries at very low prices on eBay, some with guarantees, there are even upgraded and remanufactured batteries, and sellers offering installation
    check it out
  6. richard schumacher
    7,664
    1,046
    United States
    First step: get a quote from at least one more dealer. Consider that even $4400 is probably only one year's worth of new car payments.
  7. tomfreed
    tomfreed Junior Member
    70
    Modesto, Ca
    If you go to dealer for repair you are asking for death wish to suck you dry and they will. Forget about dealer and fix it on your own. I just finished fixing my 01, 03 Prius on my own and I do have a a spare battery subpack to fix yours. Not sure your mechanic skill so here it goes.
    Scan the battery pack first determine which one is weak (less than 7.2V) then replace just that one. The pack has to be taken out of the car, safety plug remove then take the battery apart and measure each subpack with a voltmeter. The bad one will show 6.4-6.6V get them out and put the good one in then you are done. That is it and the part will cost you less than $100 depending on how many bad cell.
    No body on this forum will show you this except me since i am the one that had the most problem on the 01 that i just fixed myself. Contact me in private with your phone number so i can help you verbally. I hate to see you or anyone gets rip off with dealer charge.
    No body helps me with those Prius i bought when i was a car dealer, not at least until i found this forum. I bought a whole used battery pack from LKQ last year for the 01 and amazingly sitting in the car not running while i fixed other issues jut this week the car finally fixed and ran the battery subpacks were still good. NO code from it when i ran and drove the car:rockon:
    See pictures of me taking apart the battery last week. I had 4 bad cells that means i still have 34 good one. Good 7.2v and up, bad 6.4V - 6.6V. If you have RC battery charger there is a way to revive those weak cells. HOw do you think i know all this?:)
    Read this forum title "problem car" you will see what i went through
  8. bwilson4web
    16,204
    <AHEM>
    We've had two reports of individual module replacements:
    • Germany - worked well and as of last year, still in service
    • Florida - worked for about 3-5 months and another module failed
    Understand I have no problem with replacing modules but I look at the NHW11 modules as being weak compared to the NHW20 modules. When one of 38 modules fails ... especially due to heat ... adjacent ones are likely to be ready to go too. That was the case in Florida. But I'd like to suggest keeping your "Prius skills" current when you get to Florida.
    Hotter climates seem to wear out the modules relatively fast. Also, there is a distinct lack of NHW11 (and NHW20) expertise in the Southeast. It might bring in some 'bread and butter' money if you're interested. Just get the 2003 repair manual and the 2009 repair manual and you'll have the road map needed.
    When you head East, you might stop off at http://www.autobeyours.com/ in Scottsburg Indiana. He seems to have figured out how to stay in business rebuilding salvage Prius.
  9. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    Not sure why "disposal" is on all of those. Does the Gen I battery not have the ~$200 Toyota bounty on it that the Gen II battery does? I'm not being snarky, that's an honest question. I have been led to believe that Toyota offers money for the batteries. It would seem to make sense with all that nickel in there.
  10. bwilson4web
    16,204
    Sometimes the local Prius service center does not 'get the memo.' I've helped one user get their used traction battery recycled but I had to lean on some private communication channels.
    I did some early work on battery refurbishment in the lab but stopped when I realized the structural weakness is in the NHW11 battery terminals. The "O" ring interface deteriorates. We can restore the original capacity, the battery chemistry only loses the water, but without a fix for the leaky terminals, the problem remains. This is why I recommend going with NHW20 modules and recycling the NHW11 ones.
  11. philobeddoe
    575
    107
    Los Angeles
    i burn them
    it's hard to set them afire, which is why i use bald eagle heads for kindling :thumb:
  12. bwilson4web
    16,204
    Wait till the folks who sell scrap metal learn what they contain!
  13. Celtic Blue
    2,224
    139
    Midwest
    The bald eagle heads?
  14. tomfreed
    70
    Modesto, Ca
    Heck heat is a component killer no matter what it is especially battery. Considering the battery pack is ridiculously expensive and replacing the subpack is not that difficult i say it is worthwhile job to do it. I have 34 good subpacks to sell, any buyer?
    You don't understand i was never in a car repair business i was a car dealer fixing my own vehicle to resell. When i get to FL i won't be doing it either dealer or fixing car. I had enough grieves with a car business for 4 years in Ca already. I want to do real estate deal if do it correctly one deal can equal to someone salary for the whole year. I am on it for years now is the time to make it big. The market is buyer now for house. I might fix Prius for fun but not for making a living. I am not surprised to see East coast side Prius owner less technical than the West side. More so reason for me to pick up a used one dirt cheap then i will fix it myself for my personal use.
    You did not know this but i had a B.S degree in Electronic Engineering Technology from Cal. Poly so i am no green when it comes to electricity and electronic. They scare of me instead of me scare of them:D
  15. orange4boy
    orange4boy Member
    231
    44
    Vancouver BC
    2003 Prius
    There is someone on this forum who put gen II modules in an gen I pack. It's very DIY but possible. That's the way I will go if I have problems. Although being in Canada, I doubt that my battery would have heat related problems.
    I think Bob is right about modules beside weak ones also having problems. They tend to overcharge while the weak ones undercharge. This is why I posted the info on battery equalization. If the pack is equalized from time to time right from the start, there is less likelihood of pack imbalance causing module failure. I bet the dealers don't even know about the procedure. Although once a pack has been imbalanced for too long, it may be too late to recover with equalization.
    My two cents: Re build it yourself with gen II modules or buy a rebuilt pack and have it installed. Perhaps you could request a gen II module pack from one of the rebuilders.
    Good luck
  16. tomfreed
    70
    Modesto, Ca
    Where is your post on battery equalization?
  17. orange4boy
    orange4boy Member
    231
    44
    Vancouver BC
    2003 Prius
    It comes from the factory manual although I got it on "Alldata" which should be called "Somebadlyindexeddata"
    http://priuschat.com/forums/generation-1-prius-discussion/71521-hv-battery-board-equalization-procedure.html
    This was supposed to be done when a car had been sitting, waiting for delivery for some time. I think it would also be useful every six months or so to reduce back imbalances. It would be best if someone would document the results so we would know how well it works. Equalization is regularly done on deep cycle lead acid batteries to keep individual cells from becoming weak and ruining the entire battery.
  18. orange4boy
    orange4boy Member
    231
    44
    Vancouver BC
    2003 Prius
  19. carzen
    carzen New Member
    Colorado
    2002 Prius
    We are in the same boat - 2002 Prius with a failed cell in the battery pack. THe dealer wants $3000 to replace the pack. Why they cant isolate the bad cell and just replace that I have no idea. I have been researching this a bit and there seems to be a cottage industry rising that takes these bad packs and reconditions them to improved specs and performance. I found one business in NC but am looking for a similar business here in Colorado. They remanufacture the pack for about $1500. You would have to get the dealer to uninstall the old pack, ready it for shipment, and then agree to install the refurbished pack. I will update this thread with our progress during the next few weeks.
  20. guru_del
    guru_del New Member
    33
    Lake Elsinore, Ca.
    There is a company is North Carolina that sells them on ebay as well. I have no experience with them but i did see their listing yesterday while searching for battery packs (just in case, after all i do have 177K miles :) )
