“key number plate†essential or not?
Discussion in 'Gen 2 Prius Main Forum' started by Mike_10, Aug 26, 2010.
  1. Mike_10
    Mike_10 Member
    73
    Boston MA
    I’m the second owner of a 2008 Toyota Prius (Package II) with 23k miles.
    I have a question about the “key number plateâ€.
    There is supposed to be a “key number plate†that goes with the two smart keys that needs to be kept in a safe place in case the mechanical key is lost and you want the Toyota dealer to make a new one (p. 35 of the 2008 Owner’s Manual). I did not receive this number plate from the previous owner and I am not sure if I can get in touch with the previous owner.
    Question: Does anybody know if you can order an extra key when you’ve lost an original and also lost the “key number plate�
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    The key number plate is only for the mechanical key. You can still order a replacement without one, but better yet, have a spare cut at your local locksmith. The mechanical key is a standard Toyota blank, only it's missing the round end. Use a standard blank to make a spare.
    Tom
  3. gabrielino
    gabrielino New Member
    stuart
    I have a 5 digit number but I am not sure if it is the key number. It seems that the key number would have more digits.
  4. qbee42
    18,058
    3,074
    Northern Michigan
    Key numbers have one digit for each tumbler pin. If you have a five pin lock, you have five digits. Each digit tells a locksmith how deep a cut to make for that position on the mechanical key.
    Tom
