“Hole” in heater box
Discussion in 'Gen 3 Prius Technical Discussion' started by Julia222, Aug 14, 2021.
  1. Julia222
    Julia222 New Member
    Dallas TX
    Several years ago my AC seemed to stop blowing so I removed the cabin filter and discovered a kitchen towel had gotten sucked into the cone-shaped fan underneath. The towel was in there and since it had thrashed around there was also a lot of insulation (from the top of the glove box, I think). Now after my car interior getting soaked in the rain I am having a mold smell. The dealer is saying the problem is that "someone cut a hole in the heater box", but it appears to me to actually be a torn-out screen of some sort, which I am assuming the towel is responsible for. What sort of material was there and can I replace it? Also, what is supposed to be above that? There's no top of any sort.
    51,154
    welcome!
    how long have you owned her? tough to suck a towel in there with the weak fan and past the filter.
    hard to see, but i doubt it is accounting for the moldy smell. check the 12v battery area and spare tire for water accumulation, and all the floor carpeting.
    put a piece of duct tape over the hole for now. you might have (had) rodents if the edges look chewed.
    if not, it might be the flap area that lets a percent of fresh air in when on recirculate.
    not sure the dealer has any more clue than i do.
  3. PriusCamper
    PriusCamper Senior Member
    12,064
    4,896
    Pacific Northwest, USA
    Find a junk yard that lets you pull parts off wrecked vehicles and grab the parts that are missing....
  4. Mendel Leisk
    40,584
    I’m thinking mice. No droppings/pee?
  5. StarCaller
    StarCaller Senior Member
    1,271
    723
    Cedar Crest, NM, USA
    the 'hole' has a thin foam layer covering it (put a piece of tape over it or leave it open, doesn't matter /
    the 'open space' is just that, an open space to suck the air in when in recirculating mode /
