0-60mph ECO vs. PWR
Discussion in 'Gen 3 Prius Main Forum' started by Tideland Prius, Apr 20, 2010.
  1. Tideland Prius
    16,155
    MPG-O-Matic has done it for us
  2. Thai
    Thai Prius Neophyte
    1,197
    89
    I don't have a stopwatch on hand...so, what was the conclusion?
  3. gbarry
    gbarry Junior Member
    79
    16
    S. California
    Same. (You can watch the timer on the video player. They're both around 10 seconds.) This confirms what we've been told: Full throttle is full throttle, in any mode.
  4. dejongj
    dejongj Member
    171
    Whipsnade, UK
    Someone correct me if I am wrong, afterall I only had a 24hr test drive in one yesterday...But that video looks fundamentally flawed....Or perhaps it is just the UK version that is different...
    pressing PWR indeed give an improved throttle response, but depressing PWR puts it into automatic mode which is not the same at pressing ECO...I found driving in ECO like pressing a wet spounge with my right foot, horrible and if it wasn't an cvt'ish gearbox it felt like driving off in 3rd gear...There is no way that video was driving off in ECO mode, more like the normal automatic mode with none of the 3 driving options enabled....
  5. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    0-60 hasn't really ever been a factor though.
    0-45 is when I most often use it, which is obviously not full throttle. For those situations where traffic is really heavy and I need to dive into it.
    45-70 is another, where I'd like that oomph available from just a little bit of pedal if needed. Again when traffic is really heavy.
    For just everyday merging into highway traffic, ECO is just fine.
  6. dejongj
    dejongj Member
    171
    Whipsnade, UK
    I guess it all depends on where you live and what the traffic is like. Our house joins from a tiny little country lane onto a through route just beyond a bend....In order to join you put your foot down and get up to 60mph as quick as you can and pray :)
    Also I am in the camp of getting up to speed quickly and then easing off seems more economical (with my other cars and boat) compared to slooowly getting there...
    But fair enough european driving style is a bit more aggressive ;-)
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Okay, I'll correct you. ECO and PWR mode both have the same amount of available power. PWR mode makes the car feel snappier by front loading the accelerator pedal mapping: You get more power output for less pedal pressure. Ultimately, though, you have the same amount of power. You just have to press harder in ECO mode.
    Tom
    m.wynn likes this.
  8. dejongj
    dejongj Member
    171
    Whipsnade, UK
    Thanks for that explanation....I realise I only had one test drive, but it really didn't feel like that...Even flooring it in ECO mode didn't make it feel setting off any faster, I appreciate it will have the same power available but doesn't it also make you setoff in a different gearbox ratio (or whatever it is called in CVT land)....
  9. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Nope. No multiple ratio gears like in traditional transmissions. Just high torque electric motors.
  10. bigdog1234
    bigdog1234 New Member
    144
    23
    US
    I run in the PWR mode 100% of the time. For the first 4-6 months of ownership, I only ran in the "ECO" mode. I've seen no significant, and/ or repeatable drop by going to PWR mode.
    The reason why I prefer PWR mode is that from a stop, it's more "responsive" off the line. I prefer that feel as I dart across a busy road, or merging into traffic.
  11. Danny
    Danny Admin/Founder
    7,093
    2,108
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Exactly.
  12. qbee42
    18,058
    3,074
    Northern Michigan
    The Prius doesn't really have a CVT. It only has one set of fixed gears which never shift. At full power there is no difference in ECO or PWR modes.
    Tom
  13. guinness_fr
    guinness_fr Junior Member
    68
    france
    That's because you probably didn't really floor it all the way, that's because we almost never do that on manual transmission cars, so that it takes a while to actually get used to flooring it al the way (at least for people like me who never floored it before).
    Now I'm used to it and I prefer to drive in Eco mode as I have more control on how much input I want to use.
    PS: On my first test drive I felt the same as you did and thought I would never use the Eco mode as it definitely felt too sluggish.
  14. Jim Clark
    Jim Clark Member
    310
    22
    Northern VA, the 51st state (someday)
    Use PWR mode, you'll enjoy the car more.
  15. dejongj
    dejongj Member
    171
    Whipsnade, UK
    Fair enough, guess it requires a bit more getting used too :)
    To be honest driving a boat I'm quite used to wide open throttle...And also in the Murano with its true (albeit metal band) CVT I've used full throttle a fair bit, especially joining German Autobahn, and folling toll booths...
    Unfortunately the dealer I've been dealing with is quoting a 16 week lead time so it might be a while before we get ours :-( to try it out again...
  16. Tideland Prius
    16,155
    well if you look at the dashboard, there's always a green light illuminated. If he was in normal mode, there would be no green light (the left green light indicated ECO MODE and the right indicates PWR Mode. You'll see that they're not in the same place)
    It'll feel like taking off in "3rd gear" if you accelerate lightly. ECO and PWR affect the first 50% of accelerator travel.
    It could be that split second when the CVT revs up the engine. It can feel slower in ECO mode.
  17. Jim Clark
    Jim Clark Member
    310
    22
    PWR mode is more fun...
  18. Aegison
    Aegison Member
    404
    32
    36
    Southeast MI
    I'm disappointed with Toyota not having exploited the car's potential when in the power mode.
    It could be that I misunderstand what happens, but I think there was room for Toyota to re-map the power supplied by the electric motor to augment the ICE -- making Power a true and unique setting by going outside of the normal bounds of interaction for the electric motor and the ICE . This would be important not only at full throttle, but also in lesser acceleration situations.
    My impression is that they don't both "pile on the power" under any situation, though my impression is undoubtedly slanted because I only recently replaced my Gen II with a Gen III, and the screens didn't seem to reflect that for the Gen II.
    Did Toyota miss an opportunity there (even if it would have had to supply the same extra power whenever the throttle was all the way on in any mode)?
  19. Eoin
    Eoin Active Member
    593
    116
    Long Island
    I like my 2005 Prius, but it is very sluggish off the line compared to my 2003 Camry, partly due to the bigger engine and also to the low first gear. The Camry is just so much more responsive than the Prius. The Prius does have reasonable acceleration once you get up to about 40mph. I think this difference between the cars is mainly due to gearing, not size of engine.
  20. Ripley44224
    Ripley44224 Member
    44
    Northeast Ohio
    The graph description below talks about the "middle range." If the affected range is 50% of pedal travel, do you think the graph represents the middle of pedal travel, from 25% to 75% ?
    WanganWagon and mainerinexile like this.
