'01 battery needs replace?
Discussion in 'Generation 1 Prius Discussion' started by papatr1x, Jan 11, 2010.
  1. papatr1x
    papatr1x New Member
    Orange County, CA
    2001 Prius
    Hi. First time poster of hand me down '01 prius with just 93k miles.
    Dealer said that hv battery needed replacement. Didn't get the code for it but he said that Block 10? was damaged or something to that extent.
    He said it was going to cost $4000 for the new battery. I'm a cash strapped college student so i'll be looking in the salvage yards. Any advice?
    Also, are there any DIY links that i can look over in case i decide to do so? Thanks
    Oh and just want to make sure: the CA 10yr/ 150k warranty is for '04s and up not not my '01?
  2. adric22
    adric22 Ev and Hybrid Enthusiast
    642
    144
    Fort Worth, TX
    Not sure why you were quoted that much, the battery from toyota costs $2,300 currently. I know, I just bought one. Unless they are charging ridiculous amounts for the labor to install it?
    I wouldn't bother with the salvage yards. I tried that route and wound up wasting money because all of those batteries will have sat for months unused and will be dead.
  3. Patrick Wong
    18,200
    6,475
    You are right that the hybrid warranty is 8 years/100K miles on 2001-2003 model years.
    I agree that buying a Classic salvage battery is pretty risky because 1) they are 7-10 years old now, and 2) they are pretty costly, around $800 or more.
    If you can deal with high voltages and want to DIY, you might consider buying two 2G salvage batteries as the price is around $400 each (plus shipping) and you'll end up with 56 modules. You should be able to find batteries from 2007 or 2008 model year vehicles that have been totaled. Pick 38 modules to repopulate the Classic battery case.
    Tech manual info can be found at techinfo.toyota.com and you can also do a search for posts by Classic owners who have recently done this work. I highly recommend that you obtain the repair manual info as it provides safety tips, etc. Good luck.
  4. papatr1x
    papatr1x New Member
    Orange County, CA
    2001 Prius
    thanks for the responses
    i'll probably spring for a new battery at $2300. the DIY way sounds like a good side project if i had another car to rely on.
    But i was wondering what type of value i could get for the vehicle in its present condition or after i replace the battery? It's only at 93k mi and has a CA HOV sticker. There is some small body damage on the front right door.
  5. adric22
    642
    144
    Fort Worth, TX
    I'm not sure since you are in California. But I would imagine the vehicle would be worth between $5,000 to $8,000 here in Texas depending on the interior and exterior condition.
  6. BB_auto
    BB_auto New Member
    North Carolina
    2001 Prius
    Have you looked at eBay? There is a guy here in NC that rebuilds them using Gen II cells. It's a bit cheaper at $1500 but shipping could be the issue given you are in CA. There is also another alternative where you can rebuild them yourself but not sure that is a great idea with the Gen I cells given the problem they have with leaks.
