01 prius in dash high beam indicator not working
Discussion in 'Generation 1 Prius Discussion' started by scotman27, Sep 24, 2012.
  1. scotman27
    scotman27 Active Member
    735
    81
    PA
    2001 Prius
    Hello:ulb
    Ok my high beam indicator in my dash is not working, I pulled the bulb and checked it and it is fine, so I did a voltage test and I am only getting 1.5 volts at the light terminals, I should be getting 12 volts. Is there a wiring diagram someone has so i can see if it is the dash display itself or that I could trace back to the switch to see if it is something in the headlight switch? or does anyone know what it could possibly be. other than that, everything else works. I could probe around in there but I dont want to short something out plus I dont feel like spending 2 hours trying to figure out which wire is which.
    Thank you,
  2. ChapmanF
    17,347
    Toyota has one. It's very detailed and extremely helpful to have. If you buy it in book form (by phoning 800 622 2033 and ordering #EWD414U) it should run you about $47, but then you'd have to wait for delivery. If you're in more of a hurry, you can spend $15 on a two-day subscription at techinfo.toyota.com and download it right away.
    -Chap
  3. scotman27
    735
    81
    PA
    2001 Prius
    If I do the subscription, am I able to get pretty much the same information as I would get if I bought the service books on ebay for 165?
  4. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    Yes if not more. Plus, I you should be able to print it for use after the time is up.
