02 trunk light switch
Discussion in 'Generation 1 Prius Discussion' started by bigblock67, Jan 19, 2018.
  1. bigblock67
    bigblock67 433K with new cells
    171
    35
    Indiana
    2002 Prius
    simple question. Where is trunk light switch located please?
  2. ChapmanF
    17,326
    It's located on page 38 of the wiring diagram, which makes it look like it's beneath the center of the trunk lid, i.e., probably right at the lid latch strike.
    -Chap
  3. LEVE
    LEVE Member
    191
    97
    On the Willapa
    The trunk light is integrated into the trunk latch below the lower plastic trim. As the latch closes it opens the voltage to the trunk light.
    An easy way to tell if it's working is to lay a video camera in the trunk and shut it. If it's working... you'll know when you see the video. That's how I found mine was jammed on all the time and draining the battery if the car didn't move for a couple of days.
