03 Prius
Discussion in 'Generation 1 Prius Discussion' started by Swarg, Sep 23, 2018.
Tags:
  1. Swarg
    Swarg Junior Member
    Missouri
    2003 Prius
    So I’ve been in and out of the chats looking for info on my gen 1 Prius hybrid battery. I recently bought an IMAX B6 Charger to try and recharge the 3 bad modules I’ve found in my pack. I’ve done tons of research but still find myself slightly confused with all the lingo. I have a module currently in a 3 cycle, discharge/charge. I have the discharge set at .5a to a low of 6v. I have charge set at .5a but it doesn’t seem to let me set a high of 8v. Any advice with this process would be greatly appreciated.
  2. PriusCamper
    PriusCamper Senior Member
    11,106
    4,520
    Pacific Northwest, USA
    We're currently using 5 of those IMAX chargers that I share with a friend... They're awesome chargers and the more of them you have the faster things go, but the resistance design for automatic discharging, as well as measuring that discharge kinda sucks, varies between IMAX chargers/not to be trusted.
    Instead use one or two headlamp bulbs from your car with a cheap multi-meter and a kitchen timer. This set up will give you:
    1) exact time it takes to discharge module down to the threshold of your latest discharging cycle,
    2) the dimming of the light towards the end of the discharge will alert you to the exact moment when the threat of discharging too far is about to occur,
    3) allows you to monitor multi-meter for sudden voltage drops during discharge, which might indicate where a bad cell is before it goes totally bad,
    4) a much less error prone testing process/more clear sense of which modules are stronger, which are weaker...
  3. Swarg
    Swarg Junior Member
    Missouri
    2003 Prius
    Have you by any chance recorded yourselves doing this and put it on YouTube or do you have a link for me to watch this. My mind struggles wrapping around these ideas due to mild dyslexia but visually I can do anything. If not no big deal. I will do what you’ve suggested. It just may take me a few try’s before I “see” what it is I’m trying to do. Also huge thanks for this info. I’m about to put my head through a wall with all my research. I seem to be missing small, but important, pieces of info. The car sat for about 6 months and I was just about to junkyard it when I started to look into doing the battery myself. It started for a car for my step son, which it still is, but now I wanna see this damn thing going again, knowing I did something I started out with zero knowledge in.
  4. Swarg
    Swarg Junior Member
    Missouri
    2003 Prius
    Prius Camper,
    As I figured, I already went wrong. I believe you are saying to put a module under load, while reading voltage and timing it. I did this but thought you meant just before the light goes out. I went roughly to 1.6v at about 52 minutes. I now think you meant I will see a slight dimming of the brightness of the light at which point I will document time and voltage and disconnect. Before I go ruining anything else I’m gonna stop and research more and hopefully you can shed more light on this process.
  5. PriusCamper
    11,106
    4,520
    Yes, you understand and have accomplished the basic process correct.
    What you're missing is that you want to measure the voltage drop on the multi-meter, not just the light bulb.
    What you did with your module would be the third stage of discharge and recharge. The second stage would be dropping it down to 6v and recharge. The first stage would be dropping it down to 6.5v and recharge.
    Each module gets discharged and recharged three times. The concept is that you're gradually discharging and then recharging then discharging even deeper and recharging then discharging at the very deepest and recharging.
    The folks at Prolong say you can discharge a module as low as 0.6v, but most think that dangerously low because if you discharge to 0.0v you've ruined the module.
  6. Swarg
    Swarg Junior Member
    Missouri
    2003 Prius
    This is reassuring. So how does this process work in recharging. I put a load on it and it starts at 5.6ish but steadily drops. I just put my IMAX on it at .1 volt and it’s set for 1 hour I believe. Now, for the voltage drop. I’ll actually see the voltage go from a fairly regular drop to a sudden drop, whether it’s a sudden .5 or .8, but I’ll see a drop unlike the rest as I watch? Again, thank you. You’ve already help me put a few missing pieces in this puzzle and it’s making more sense
  7. ChapmanF
    15,674
    They can't possibly mean that ... that would be a daringly low discharge voltage for a single cell, and there are six of those in a module. That would mean 3.6 volts for the module. I've seen 1 volt or 0.9 volts suggested as reasonable discharge limits for a cell, which would be 6 or 5.4 volts for a module.
    -Chap
    PriusCamper likes this.
  8. PriusCamper
    11,106
    4,520
    I don't use the IMAX for discharging, it's not reliable... So I don't know what you mean by setting the Imax to .1 volt for an hour but I already clearly said Prolong says absolut limit of discharge for a fully balanced module is .6 volts, because their are 6 cells in each module. Hope you didn't just kill a module? Did you recharge it before you started discharging? I sure hope so!
    #8 PriusCamper, Sep 26, 2018
  9. PriusCamper
    11,106
    4,520
    Yes, the electrical engineers at Prolong recommend doing manually, or via their automated discharge system a third level discharge to 17 volts on the whole pack, which divided by the 168 cells in pack calculates out to .1 volt per cell... Many of folks on Prius chat think that number is too low in terms of risk and I tend to agree. But as far as Prolong is concerned, they're the ones who handle the liability on their product, not us, so it must work pretty well... Having a balanced and full charged pack is key before you push that level of discharge though!
  10. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    If you have known 3 bad cells, why don't you just replace then??
  11. PriusCamper
    11,106
    4,520
    Yea... "Fixing" a confirmed bad module with charging and discharging is probably not going to work, but the process of "confirming" that the module is bad could include this process. I'm not sure what OP means by "bad" module in this instance, but figure they'll figure it out if they keep at it long enough and didn't want to offer up too much info for the sake of simplicity.
  12. Swarg
    Swarg Junior Member
    Missouri
    2003 Prius
    Bad as in not holding a starting charge of 7.2ish volts and I was trying to stay brief and as exact as possible. Should I just buy 3 new modules? I keep reading from some that they have done this and it’s fine and then others say not to. I find those that say not to are usually selling rebuilt batteries or something for rebuilding. If I do this, how do I ensure they are within range to not throw codes. Each pair of modules need to be within .2? Is this correct? I’m open to any ideas and suggestions that can get this car going again for the boys. You guys tell me what I need to do. I’m far less experienced here. YouTube and lots of reading articles is how I’m learning.
  13. PriusCamper
    11,106
    4,520
    I've had the experience of putting in a crappy ebay module that didn't make it 10 miles before it failed... I've had the experience with buying really top notch high quality modules that threw error codes because the remaining pack modules weren't as good as them. The former is something you can't do much about other than get a refund... The latter, sometimes battery pack reconditioning can get the old pack's modules to be restored to match up close enough to newer better ones. But in general I'll do all I can to avoid breaking up a pack and adding a different module.
  14. Swarg
    Swarg Junior Member
    Missouri
    2003 Prius
    Alright. I just ran over the 3 modules that I’m trying to “fix.” One is 6.5 immediately under load and slowly drops over time. This is the new part that I wasn’t aware of because I’ve been focused on that single module as I learn. The other two come up -5.8ish volts and drop steadily under load. Reverse polarity correct? Do I have any hope for this pack(all 38 modules), or do I scratch the whole thing. I don’t have 1500$+ at the moment for a battery. Do I order all new modules? Can the reverse be fixed?
  15. ericbecky
    ericbecky Hybrid Battery Hero
    4,371
    3,222
    Madison, Wisconsin
    6.5v? Bad.
    5.8v? Trash.
  16. Swarg
    Swarg Junior Member
    Missouri
    2003 Prius
    So my next step?
  17. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    If you need to do it kinda on the cheap, buy more old modules and keep at it. It's not going to be straightforward, and you will probably go through multiples of what you need to find compatible modules. If you want to rebuild to a better battery, check every C/L within a day's drive and try to find a later Gen2 or a Gen3 battery to mine for newer modules and then buy some individual modules to make up the difference. They aren't mix or match, you'd have to replace all of the old ones with new generation ones Something out of a totaled out Prius is what you're looking for.
    Replacing modules in your old battery is probably a losing proposition. As you know, they've got to match up pretty closely, and as they're all kinda old, you'll replace a bad one and another will pop up.
  18. Swarg
    Swarg Junior Member
    Missouri
    2003 Prius
    I was just looking around on the web for something like you are saying. See if I can find a totaled Prius. I will ease my brain and slow myself up here and put my efforts towards this for the time. Side note: my parents both grew up in Tucson. Believe my dad graduated from Pueblo High and not sure about my mom. Still have some family from both sides there.
  19. PriusCamper
    11,106
    4,520
    Did you recharge the modules after the load test?
    I thought you were conditioning, not load testing... Load testing needs to be done once you've recharged, not after you discharged.
  20. PriusCamper
    11,106
    4,520
    That's true with Honda, but Prius is much more flexible with replacing modules, which is why there's so many hacks on Craigslist making good money selling sloppily "rebuilt" packs that last for a while. And if you're super thorough and do everything right a module replacement can last a year or longer.
