04-05 (NOT 06-09) Prius owners w/HIDs - how long did they last?
Discussion in 'Gen 2 Prius Main Forum' started by cwerdna, Jul 2, 2011.
  1. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Since 06-09 Prius owners w/HIDs were included in Toyota Prius HID Headlight Class Action Settlement - Consumer Class Action Attorneys - Girard Gibbs LLP, I'm curious about how long the HIDs in 04-05 Priuses typically lasted?
    Model years 06-09 went to Philips D4R, which I later found out are mercury-free, while the D2R bulbs in the 04-05 models are not. Maybe Toyota did this as part of RoHS or something...
    My passenger side D4R on my 06 started going out a few months and ~800 miles after the 5 year/50K mile warranty that we got as a result of the class action suit. Skimming some earlier threads, I've heard of some folks past 110K miles on their 04 or 05 HIDs... IIRC, one guy said he had trouble at ~88K miles or so...
    If yours burned out "early", did you use them as daytime running lights or cycle them a lot?
  2. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I swapped mine out during my projector project. After 134000 miles they were still working fine. I even tried swapping to new bulbs and nothing except color changed which is why I moved on to projectors for more output.
    So to answer your question, 134000 miles and they were still working fine. I used them as DRL s alot too.
  3. Ct. Ken V
    Ct. Ken V Active Member
    535
    57
    Bolton,CT
    guys,
    I have an '05 with 111,000 miles & I'm still on the original D2R HID bulbs which I do NOT use as daytime running lights (not a lot of on/off cycles either). Some have speculated that leaving the light switch on (to use as DRL's) causes a high power surge to the bulbs on start-up that may be destructive to the HID bulbs. Yes, the nature of HID bulbs is for the ballast to use high current to fire the arc & then reduce the current to maintain the arc once lit. But that normally happens with just 12 volts applied when you turn on the switch normally. What I'm talking about with the H/L switch left ON is the 14.0 to 14.5 volts that may reach the bulbs as the DC to DC inverter is energized on start-up. But I'm NOT an electrical engineer, so what do I know.
    Hey, cwerdna, what does RoHS stand for?
    Ken (in Bolton,Ct)
  4. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Rodents of Hunusual Size? I don't think they exist. : p
  5. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    RoHS = Restriction of Hazardous Substances? Maybe the restrictions would apply to giant rodents, too.....:bolt:
    I changed a bulb recently at about 90,000 km, but other wise the headlights have worked well. Being a Canadian model, the car uses DRL but not HID.
  6. bisco
    51,994
    my daughters 04 w/ 85,000 still on originals. hope your not jinxing her.
  7. cwerdna
    12,544
    2,124
    SF Bay Area, CA
  8. spitinuri
    spitinuri Member
    317
    190k miles and still original
  9. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    Amazing! I seriously doubt anyone has had D4R bulbs in their 06-09 Priuses last that long.
  10. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    You guys know better than I, so you tell me: do I have the HID? I think I do.
    (some Prius expert, huh?)
    If so, almost 90,000 miles and they're still fine. And I use them as DLRs so they cycle on/off every time I use the car.
  11. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    In the U.S. HIDs only came as a package with foglights. Go turn on you headlights and if they start off with a blue tinge then shift to a whitish light then you have HIDs.
    H IDswill lose lumens over time and after 2000 hours could be down on lumens by 75%. So for those with very high mileage and use them as DRLs may want to replace them despite a lack of failure.
  12. TonyPSchaefer
    14,816
    2,501
    66
    Yeah, those are mine. I might stop using them during the day. The only problem is that after all these years of not having to think about them I might forget to turn them on.
  13. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    108,000 miles, have had my '04 since Oct. '03 and am still on the original HIDs. Did have to replace a tail light bulb though.
  14. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i replaced mine around 145k miles. i kept cycling them on knowing i could potentially be wearing out the bulbs and the ballast... shrug...
    sometimes i wonder if it's the connections instead of the bulbs... bumps causes my right one to clip off and it's new.
  15. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    '04 with 80k miles...still have the originals.
  16. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    A little over 100K now and no headlight problems.
  17. hschuck
    hschuck Member
    385
    bay city, ca
    Original HIDs, no problems. 05 w/94k miles.
  18. krousdb
    krousdb NX-74205
    580
    500
    47
    Raleigh, NC
    256k miles, original HID's, no problems at all. And even though one of my foglight lenses acquired a large hole, both fog lights are still working fine.
  19. brownsnoutuk
    brownsnoutuk Active Member
    185
    119
    Shepherd, TX
    still original
  20. djasonw
    djasonw Active Member
    961
    123
    Coconut Creek, FL
    '04 Purchased Nov '03. 147k/Original HID's.
