04 gen 2 Prius High Beam not Working, Help pls
Discussion in 'Gen 2 Prius Audio and Electronics' started by PANN KETYA, Mar 28, 2020.
  1. PANN KETYA
    PANN KETYA Junior Member
    32
    Camboida
    Hello everyone,
    I have a Prius 2004 and recently, high beam just stop working while Low beam working fine.
    If anyone as experience with such problem please help, thanks a lot.
    Links for video, sorry I can't attach here.
  2. ydpplqbd
    ydpplqbd Active Member
    551
    253
    Have you checked the fuse being. IIRC, there is a separate fuse for low beam and high beam.
    PANN KETYA likes this.
  3. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    yep. check the fuses first, 2nd possible both bulbs are bad. other than that, you'll need a meter to check voltage and ground at the sockets. switch itself could be bad. need a meter to check that too.
    Longinus876, PANN KETYA and ydpplqbd like this.
  4. PANN KETYA
    32
    Camboida
    It sometime working just fine. So if fuse blown then it will never be working. Can you tell where them fuses are? Under steering or hood?
    Thanks
  5. PANN KETYA
    32
    Camboida
    Does it has anything to do with clock spring?
  6. ydpplqbd
    551
    253
    It appears that the headlight fuses are underhood. Further, it appears that there are four fuses numbered and specified as follows:
    26 RH low beam (10A fuse for halogen and 15A for HID)
    27 LH low beam (10A for halogen and 15A for HID)
    28 RH high beam (10A)
    29 LH high beam (10A)
    See: Toyota Prius (XW20; 2004 - 2007) - fuse box diagram - Auto Genius
    PS I have no information on the configuration used in Cambodia. Your Gen2 may vary from pics and linked info as it was apparently placed in service outside of North America.
    #6 ydpplqbd, Mar 31, 2020
  7. fotomoto
    fotomoto Senior Member
    5,633
    3,808
    So. Texas
    For intermittent problems, check the headlight stalk (switch) and wiring harness connection at the steering wheel and replace as necessary.
  8. ydpplqbd
    551
    253
    Down below is a link to an older Priuschat thread where that poster had a similar problem as your problem. That poster solved the problem by converting from HID bulbs to LED bulbs. Food for thought. I have halogen bulbs in my Gen2 (and therefore have no real life experience with the Gen2 HID system). Let us know how you make out.
    Link: HID to LED conversion | PriusChat
  9. PANN KETYA
    32
    Camboida
    I just tried replacing all those 4 fuse but so far high beam still not working.
  10. PANN KETYA
    32
    Camboida
    I have ordered the clock spring to replace already but just not yet arrived. Weird things is that high beam symbol on dashboard working just fine.
  11. Longinus876
    Longinus876 Member
    105
    Long Island
    Of course! The switch. I think you just solved the mystery. How do I check the switch?
  12. Longinus876
    Longinus876 Member
    105
    Long Island
    Excellent thought! How do we check those switches?
  13. Jertanga
    Jertanga New Member
    Houston
    Hello I have a 2009 Toyota Prius hybrid when I first got it the screen on the display was cracks so I tried to replace the plastic part but that didn’t work so I just got a whole new display off of eBay after I installed it my dash lights and the display started acting up some days neither would come on or some days only the dash would come on but if I cut the car on and come back they both would be off I tried replacing the fuse still didn’t work do anyone know what it could be
