'04 Prius have a DOUBLE DIN?
Discussion in 'Gen 2 Prius Audio and Electronics' started by fadetogloss, Apr 11, 2008.
  1. fadetogloss
    fadetogloss New Member
    Denver, CO
    Ive looked all over online and had an installer at Best Buy search to see if an '04 Prius is considered a double DIN by removing the CD player/pocket. but everything has just said its "over sized"...
    Anyone know? Im trying to see if a Pioneer D3 will fit in there.
    Thanks,
  2. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    The pocket underneath the stock stereo is Single DIN. On Crutchfield, they sell the Prius Dash-kit and that is only Single. With some fiberglass fabrication, I'm sure a Double DIN would fit.
  3. fadetogloss
    Denver, CO
    but by removing the cd player AND the pocket does that make it a double DIN (sorry I'm a techie at heart but a noob to cars)
  4. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    If you were to remove the current head unit, there is plenty of room.
    I just found THIS PAGE and it shows a single din with room to spare. Oversized means 1.5 maybe? if you include the lower cabinet, it's almost a tripple.. if that exist...
  5. fadetogloss
    Denver, CO
    whats are the best mounting kits?
  6. V8Cobrakid
    3,790
    152
    off hand?.. no clue. all i'm going to do is google it. I'll read through piles of failed solutions before i find a few that work. then i'll post them here. :)
  7. Gun owning Prius driver
    397
    78
    Downey, California (Los Angeles Area)
    I believe scosche TA 2103b works I read that others used that on the Prius
  8. Sparky9292
    Sparky9292 Junior Member
    37
    Earth
  9. Gun owning Prius driver
    397
    78
    It can be done, you in cali? I know a few spots either make a kit or fiber glass it.
