04 Prius - Installing Backup Camera - Need Power Source for Monitor
Discussion in 'Gen 2 Prius Audio and Electronics' started by thegoldenhand, Oct 23, 2014.
  1. thegoldenhand
    thegoldenhand Junior Member
    44
    California USA
    Hi guys! Need your help. I'm in the process of installing a backup camera on my 04 Prius. I opted to buy a separate 4.3" monitor instead of doing the NAVtool route which was obviously the more expensive but cleaner solution. I got everything hooked up. Camera has power and signal is good when I switch to reverse. The video cable is routed to the front now.
    The only thing I really need now is a power source for my monitor. I dropped the wire to the harness plugs right next to the foot brake. But I don't know which plug has the 12v feed. I posted a picture of the plugs I am looking at and hopefully someone can help me figure out which wires to tap into for positive and negative.
    I could run the wires to the cigarette lighter but that will be my last resort. There's a bunch of wires on these plugs and for sure there will be a good source here. Just don't know which harness plug to tap into.
    Any help is greatly appreciated. Thanks!
    which for power source? | Flickr - Photo Sharing!
    #1 thegoldenhand, Oct 23, 2014
  2. thegoldenhand
    44
    California USA
    So I decided to remove the driver seat and figure out how to tap on the navigation harness. I am reading that the gray wire in the main plug is switched 12v. Is that correct? Also what is the negative wire color in that harness? black?
  3. Mutual
    Mutual Junior Member
    The grey wire is switched and connected to the 7.5A Accessory fuse. Ground is the white and black wires.
    thegoldenhand likes this.
  4. thegoldenhand
    44
    California USA
    Thanks Mutual! I ended up just tapping from the cigarette lighter in the dash. Works perfectly now. I added a rocker switch in case I am not backing up and the screen turns blue. That way I can turn it off via the switch.
