'04 Prius No Display
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by priusinconn, Jan 1, 2009.
  1. priusinconn
    priusinconn New Member
    Storrs-Mansfield.Connecticut
    In cold snowy Conn. My 2004 Prius will start, run,all lights work head,tail & turn. No lights no display gas gauge MPH cannot be read. Car is to go to dealer for 105K service Tuesday 1/6/09. Any ideas why this happens & what can be done to remedy the problem?
    priusinconn
  2. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    Sounds like a fuse is blown. Check for that.
    Hopefully, it's just a fluke.
  3. richard schumacher
    7,663
    1,038
    United States
    And you checked that the thumbwheel switch for the display brightness has not been dialed to minimum?
  4. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    271
    Harrisburg, PA
    +1 for this. Quite scared me when it happened to me. If you can see the display with headlights off and not when on, the dimmer is the problem.
  5. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Are you sure you didn't turn off the display? Press the Info button should bring it back to life if it was turned off.
    Oops, I too thought the OP was refering to the MFD...
  6. patsparks
    10,664
    567
    Adelaide South Australia
    I was going to say the same. Dimmer.
  7. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    i believe to turn on the display again, once holds the display button down and keeps holding it until it turns on. i think info is the wrong key. but i might be mistaken
  8. Patrick Wong
    18,200
    6,472
    If the instrument panel display still cannot be read when the headlight switch is turned OFF or when you make sure the display panel dimmer wheel is turned up fully, then look for the 10A GAUGE and 15A DOME fuses and see if those are OK.
    If the fuses are OK, then it would be reasonable to report the problem to your dealer.
  9. Ct. Ken V
    Ct. Ken V Active Member
    535
    57
    Bolton,CT
    Hey, priusinconn & rigormortis,
    Regarding the second's answer to the first : on my '05 to turn the display back on (once it's off), pressing & holding the display button to the right of the MFD does nothing except give one beep. To bring my screen back on, I press the info button to the right of the MFD (& assuming the brightness wheel on the lower left end of the dash is turned up far enough), when the screen starts to come to life, I touch the "trip info" box on the MFD screen & that will bring back your normal displays of energy/consumption & a/c & audio.
    If that doesn't work, then yes, go check the fuses mentioned.
    Priusinconn, I'm just down the road from you, just over the Coventry/Bolton town line, right off of Rt.44, near Indian Notch Park, on Bolton Lake. Who's doing your service? Lynch's in Manchester?
    Ken (in Bolton,Ct)
  10. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    is anything covering the glass where the speedometer image is reflected? check simplest possibility first.
  11. patsparks
    10,664
    567
    Good point Galaxee, I was thinking MFD but OP has a problem with speedo display. doh!
