04 Prius Wont Start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TeeTee97, Mar 6, 2020.
  1. TeeTee97
    TeeTee97 Junior Member
    Didnt have my gas cap screwed on tight and Red light, VSC, and ! light came on. I was told if I ride it for a couple of days lights should go out. After a couple of days, when I went to turn on my car, nothing happened. My headlights turn on and if I leave the key in the car with the door open, it beeps. Tried holding the start button for 45 seconds, nothing happens. Can someone tell me where to look next or what the problem may be? Thankds
  2. JC91006
    16,477
    8,394
    1. The problem is not your gas cap, that would only light up the "check engine" light. Not all the lights you listed.
    If I had to guess, I would say your hv battery is the problem
  3. TeeTee97
    just had it repaired. The copper things (not sure what they are called) were cleaned and replaced and the cells all tested at 8.7 Thx for that info.
    49,387
    Dead 12 volt battery
  5. TeeTee97
    Thanks for your reply. Will have it checked.
