04 Prus check eng - DTC0000
Discussion in 'Gen 2 Prius Technical Discussion' started by Ron Walker, Sep 8, 2008.
  1. Ron Walker
    Ron Walker VP21
    Working on an '04 Prius with 88,000 miles.
    Check engine lite is on. Use Scan Gage and get P0000.
    I shut the lite off and it returns in 15 - 30 seconds.
    An earlier code was P0010. I checked the Valve advance and had a loose plug. NO repete on this code.
    How do you fix a 'no problem' P0000 DTC????
    Thanks
    Ron
  2. Patrick Wong
    18,200
    6,474
    Hi Ron,
    If the CEL is on, then the engine ECU definitely logged a DTC. If your code reader does not offer a valid code, then you will need to use a better code reader.
  3. Ron Walker
    Ron Walker VP21
    Thanks for the input
    I'm Using a scanII bought through this forum. The scanner shows P0000
    so it is geting a stored code and will shut the light off.
    I Pulled the NEG wire off the battery for 10 minutes but still have the same problem.
    Ron
  4. miaxapa
    miaxapa Junior Member
    Cashville Va
    Put a hat in front of the light?
  5. ias513
    ias513 New Member
    Hershey, Pennsylvania
    2001 Prius
    I am having a similar problem, but the light only comes on when driving under a higher load condition. I read somewhere that the Scangauge can cause the problem.
    Try disconnecting the Scangauge and see if the P0000 still returns.
    Let me know...
