05 cant read trouble codes
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by balmeral, Mar 31, 2011.
  1. balmeral
    balmeral Junior Member
    Iowa
    I have a 2005 prius and I got a scanguage to read the codes. I have two lights on my dash. One is the check engine and the other is the (O) light. I think this is something to do with the regen braking. Anyways when I run the scanguage it says no codes found. What type of scanner would be able to pull up all prius codes? Thanks!
  2. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    Probably the Toyota one is needed... you may need it to talk to the skid control ecu. I think the scangauge only sees the main ecu but there are lots in the prius.
  3. richard schumacher
    7,664
    1,043
    United States
    Yup. There are many proprietary codes that a generic ScanGauge won't see or report.
  4. balmeral
    Iowa
    Are there any scanners that CAN read these codes? The dealer wants 70$ to read these codes and I would rather spend the 70 on something I can keep using to read the codes.
  5. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,517
    38
    Santa Fe, NM
    AutoEnginuity will read these codes, but costs $400. You can jumper the data link connector to get skid control or air bag codes.
  6. balmeral
    Iowa
  7. seilerts
    3,326
    1,517
    38
    Santa Fe, NM
    Not quite, you need the Proline connector with a Toyota add-on. They only sell it on their website, autoenginuity.com
