05 Prius engine won’t start after main HV battery pack replacement.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by KenStewart, Feb 28, 2019.
  1. KenStewart
    KenStewart New Member
    Colorado
    I replaced two battery cells out of the main HV battery pack using all safety recommendations from Toyota. Everything went well and the car worked afterwards. I made the mistake of testing the voltage incorrectly and the battery failed shortly after. I replaced a third cell. Now when I push the power button, the computer comes on but no speedometer and no running engine. I figured I must’ve triggered a code or something so I re-did it, same thing happened. I have most of the normal procedure down very well since I have done it three times. If anyone has any suggestions it would be greatly appreciated.
  2. KenStewart
    Colorado
    The codes that trigger are:
    P3030
    P0A0D
    P3000
    P0420
  3. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Welcome to PriusChat!!
    What kind of OBD2 reader are you using to retrieve those DTCs with?
    For that P0A0D - first check the orange HV battery interconnect, did you install it correctly? (flip up, push down)
    Here are the workups for the DTCs in the order you've posted them, for DTC P3000 you will need the sub code (INF) to narrow it down :
    P3030 : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/Prius%20Service%20Manuals%202004/%E4%BF%AE%E7%90%86%E6%89%8B%E5%86%8C/04pruisr/05/20zmw/cip3030b.pdf
    P3000 : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/Prius%20Service%20Manuals%202004/%E4%BF%AE%E7%90%86%E6%89%8B%E5%86%8C/04pruisr/05/21bpm/3000123.pdf
    P3000 : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/Prius%20Service%20Manuals%202004/%E4%BF%AE%E7%90%86%E6%89%8B%E5%86%8C/04pruisr/05/21bpm/3000388.pdf
    P3000 : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/Prius%20Service%20Manuals%202004/%E4%BF%AE%E7%90%86%E6%89%8B%E5%86%8C/04pruisr/05/21bpm/3000389.pdf
    P0420 : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/Prius%20Service%20Manuals%202004/%E4%BF%AE%E7%90%86%E6%89%8B%E5%86%8C/04pruisr/05/2054m/cip0420.pdf
    Skibob and Raytheeagle like this.
  4. gregT
    gregT Junior Member
    holmen
    Yeah, double/triple check that you not only flipped the lever, but SLIDE the lever after its flipped.. I did the same thing..
    Note: this is NOT my video...
