05 prius techstream brake bleed
Discussion in 'Gen 2 Prius Technical Discussion' started by Travis Davis, Apr 22, 2017.
  1. Travis Davis
    Travis Davis New Member
    27
    Seattle
    I have the tech stream software with the mini VCI.I haven't been able to find any kind of a tutorial on the brake bleed procedure and I would like to bleed my brakes soon as the fluid is yellow and i dont think it's ever been changed. Does anyone have a link to a turtorial or anything like that for how to bleed the brakes using techstream?
  2. greasemonkey007
    greasemonkey007 Active Member
    287
    106
    South Central Arkansas
    I've tried 3 or 4 times to execute and all I get is refer to tech manual for procedure. I haven't bought the 2 day pass just to see if there was a hidden key.
  3. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    No. You just select normal brake bleed from Techstream and then bleed the rear brakes while holding the brake pedal down.
    05PreeUs likes this.
  4. greasemonkey007
    287
    106
    Thanks, I'll try that some time.
  5. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Pretty sure this is what you are looking for : http://techno-fandom.org/~hobbit/cars/TIS/ileaf/04toyrm/04toypdf/04rmsour/2004/04priusf/32/219qc/f040001.pdf
    Just be sure to use your mini-VCI device in place of the mentioned hand held device.
    Please tell us about your flush/bleeding process afterwards ;)
  6. Maze62
    Maze62 New Member
    Central New York
    This is what I was looking for! Thanks!!!
    SFO likes this.
