05 Prius With Codes
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Hank Williams, Jun 17, 2020.
  1. Hank Williams
    Hank Williams New Member
    Jacobsville Md
    The dealer say I need a new ECU in the battery and a new cell and a sensor . The fan is too loud in the back. here are the codes. I had the car in the garage for 9 days while I was in ocean city on vacation. My 12V Was 12.89 When I Tested It.
    P3000 - HV Battery Control System Malfunction
    P3024 - Battery Block 14 Becomes Weak
    P0A7F - Hybrid Battery Pack Deterioration
    P0A80 - Replace Hybrid Battery Pack
    P0AFA - Hybrid Battery System Voltage Low
    P0A1F - Battery Energy Control Module
    P0AC1 - Hybrid Battery Pack Current Sensor 'A' Circuit Low
    C1259 - HV System Regenerative Malfunction
    C1310 - Malfunction In HV System
    B1424 - Solar Sensor Circuit Driver Side
    U0293 - Lost Communication With Hybrid Vehicle ECU
    #1 Hank Williams, Jun 17, 2020
  2. Hank Williams
    Jacobsville Md
    F66AF54A-1B6E-4E05-9A64-EDE3EFAE4943.png CCD6AAF3-D18F-470D-88BF-22E262AB47C3.png I was using my my mini van for ocean city! The battery is fully charged. Which I never seen before until yesterday.
  3. PriusCamper
    PriusCamper Senior Member
    11,103
    4,516
    Pacific Northwest, USA
    I've seen this problem more than once... The corrosion connecting the modules is bad, so bad that the corrosion is also on the voltage sensing wires where they plug into the hybrid battery ECU, which eventually shorts out the ECU.
    While most dealers charge $5K to fix... Myself and other charge $500 to 1) replace w/used battery ECU ($50), 2) Replace voltage sensor harness aka: Wire Frame No2 ($50) 3) Replace bus bars and nuts with new or clean, 4) full diagnostics on all 28 modules, which includes 3 increasingly deeper discharges and recharge aka: reconditioning. 5) replace bad modules.
    edthefox5 likes this.
    49,478
    that sounds a bit high for the 12v, how old is it?
    how many miles on your car?
  5. Hank Williams
    Jacobsville Md
    150K 12V Is 15 Years Old
    Would a use battery Be better Then a new
    #5 Hank Williams, Jun 17, 2020
  6. PriusCamper
    11,103
    4,516
    If you're rich and you have plenty of money than yes a brand new pack is the way to go... But if wasting money hurts you... Then no...
    But more to the point, if your 12v battery is really that old (I'm skeptical) that's the first thing to deal with and might solve all you problems...
  7. bisco
    49,478
    how did you get the 12v reading of 12.89?
  8. PriusCamper
    11,103
    4,516
    Here's the best way to test your 12v battery:
