05 Prius won’t start after repairs
Discussion in 'Gen 2 Prius Technical Discussion' started by Bmyers, Mar 9, 2018.
  1. Bmyers
    Bmyers New Member
    Idaho
    05 Prius..Lord help us!! Heater stopped working..got the P119 something like that code. Replaced that part. The belt then snapped stranding me on the side of the road. Vehicle was towed. Replaced water pump, new 12v battery, oil change/filter/air filter/coolant...the whole shebang. Now the damn thing won’t start!!! The engine part that is. It tries to come on, problem light comes on, and then it shuts off the motor. Keep having to unplug the battery to reset it. There has to be someway to bypass the computer for the motor to run long enough to recognize new fluids and parts etc. But we cannot figure it out. Have to get this vehicle to our Marine ASAP! Any assistance would be greatly appreciated.
  2. dolj
    dolj Senior Member
    7,643
    3,858
    Wellington, New Zealand
    So what codes does the car have? What lights are on on the dash?
  3. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    Without codes, my guess would be either your 12V battery is weak, or the traction battery.
    Even a new 12V battery, could be weak. Have the battery loaded tested
  4. ericbecky
    ericbecky Hybrid Battery Hero
    4,371
    3,220
    Madison, Wisconsin
    Any chance the oil is overfilled?
    Check the dipstick and post a pic of it. Prius do not like to be over the fill line.
    Raytheeagle likes this.
  5. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    Worst case scenario: you could have run the HV battery down too low when you had troubles on the road and now it doesn't have enough "juice" to crank start the gasoline engine. The car has trouble codes that need to be read.
    GOOD LUCK!
  6. padroo
    padroo Senior Member
    2,763
    2,250
    You are missing one digit in your code but a P0119 is Engine Coolant Temperature Intermittent.
    Check your coolant level and like mentioned have your 12 V battery tested. Strange things happen in a Prius with low 12 Volt battery voltage.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    The belt snapping is ominous. You don't know it snapped and continue driving till the check engine comes on as its in overheat.
    Usually severe overheat.
    Because the belt powers the engine water pump. No belt no pump. Terrible design no warning if belt goes. No temp gauge.
    If any lurkers watching this replace your belt after about 75000 miles as it will start to show wear. Its strictly preemptive. Keep a healthy belt on the car. Lose the belt it sometimes will toast the engine or your wallet.
    The overheat may have blown the head gasket or siezed the engine.
    Please explain in detail the belt snapping circumstances please. Was there smoke coming off the engine at the end of this scenario?
    How bad did it overheat?
