'05 shakes when engine shuts off.... need new engine mounts?
Discussion in 'Gen 2 Prius Main Forum' started by Integraoligist, Nov 27, 2013.
  1. Integraoligist
    Integraoligist Junior Member
    46
    So I just bought this '05 about a month ago and I notice that the car shakes a good amount when the engine shuts off... you can really notice it when your sitting at a stop light and such.
    Is this normal? Or do I need new engine mounts or what?
    Thanks all!
  2. usnavystgc
    3,159
    989
    Tucson, AZ
    Well, it's hard for me to judge from here what a "good amount" is but I'm willing to bet that what you're experiencing is normal. Unless your car has been in an accident, engine mounts should last about 20 years (my guess, not a scientific answer so don't shoot me fellow chatters) or at least outlast the engine. I've never heard of engine mounts going out on a Prius yet (of any generation, even Gen I).
  3. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    I have seen reports of rough idle and shut down due to fuel system issues (injectors or MAF dirty) but without any DTC to report it would be just guess work. I think normal shut down is smooth, not even noticeable while driving at speed.
  4. vskid3
    vskid3 Active Member
    773
    228
    Mine does the same, especially the shutdown going into stage 4. It doesn't seem like an issue, I've read others have experienced similar.
  5. wb9tyj
    wb9tyj 2017 Prius Prime Advanced
    389
    94
    Indiana and Nevada
    i would say sounds normal…especially when its colder outside…our 04 did that all the time…as well as our 09…so unless you have a bad injector or bad gas…the rough idle on shutdown is "normal"…
  6. Bob the Builder
    Bob the Builder Junior Member
    26
    US
    The engine looks for an easy restart spot. If it does not stop right it pops it over to a new spot. Sometimes it shudders a little. No problem, mine does it about every other time.
    SFO likes this.
