06 completely shut off while driving. Electrical fire smell.
Discussion in 'Gen 2 Prius Main Forum' started by Jackoar, Aug 27, 2017.
  1. Jackoar
    Jackoar Junior Member
    22
    Long beach Ca
    So just about an hour ago I was driving my 06 listening to the radio and everything just shut off completely. I had to pull to the side of the road immediately. No kinda of warning or illumination at all. Will not restart. Hazards and turn signals are working. Lock and unlock.. No response from power button. When it died I got out and smelled electrical fire smell. Not an actual fire tho. I pulled the back apart quickly and the smell wasnt coming from either of the batteries. i dont think either of them are involved in this issue. I could really smell it while standing outside the car in the rear area. Nothing from the front. anyone have any experience with this?
    52,391
    inverter pump maybe? that's under the hood though. cat? not sure that would shut down the car.
    maybe there are some other things in the back i'm not aware of. how about the battery cooling fan?
    Raytheeagle and Jackoar like this.
  3. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Check main fuse(s). If so, need to find out why.
    kenoarto and Jackoar like this.
  4. Texas Hybrid Batteries
    Texas Hybrid Batteries Senior Member
    271
    563
    Dallas -Fort Worth
    Inverter cooling pump shorted out and popped the AM2 fuse under the hood. The pump is behind the drivers side headlight. If you check that area it will likely be the source of the smell. This has become such a common problem now days, I bet we see 3 or 4 a week that do this exact same thing.
    Replace the pump and the fuse and you'll be back on the road.
    Rph74 and tvpierce like this.
  5. Peter Fanelli
    Peter Fanelli Junior Member
    36
    Smyrna, Tennessee
    This sounds like the same thing that happened to me last Thursday in my 05. I got a red triangle a couple of hours before and I was sitting at a traffic light when there was a burning smell and I got smoke wafting up outside on the passengers side. It shut down and would not restart. Strangely the radio/hazard flashers/door locks still work, 12 volt stuff, and the headlights work. Try to start it and it just shuts down again with only the squares around the transmission selection showing on the dash. With 408,000 miles on it I suspect it's done.
  6. JC91006
    16,827
    8,600
    Are we going to get a second recall? The pumps are still shorting out, the danger is still out there
  7. Texas Hybrid Batteries
    271
    563
    Dallas -Fort Worth
    Or you could spend $125 on a new pump and keep on driving it. I could understand your "time to retire the old girl" attitude if it was your hybrid battery that died but that's not the case. This is probably one of the easiest and cheapest DIY repairs on this car. Just fix it.
  8. JC91006
    16,827
    8,600
    I just helped a member fix this pump yesterday, pinched the hoses and it's a breeze.
    But if you take it to the stealer, it'll cost $500
    Raytheeagle likes this.
  9. Peter Fanelli
    36
    Smyrna, Tennessee
    Is it likely that it was the pump itself that was the source of the smoke?
  10. dolj
    dolj Senior Member
    8,559
    4,349
    Wellington, New Zealand
    Yep, sure is likely. Likely popped the AM2 fuse too, so make sure that is checked and replaced, if necessary, after you replace the pump.
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    That pump was part of a service campaign a few years back where the dealer was replacing them for free. I don't think thats available anymore. Maybe your car has never seen a dealer and was on the original Inverter coolant pump. Mine was replaced FOC by the dealer then.
    If your car has never seen the dealer theirs also a few other TSB's out for the car and you can take it to the dealer and they will scan the car for free for available technical service bulletins.
    There was a steering TSB also. That ones kinda important as the steering can fail while your driving.
  12. Peter Fanelli
    36
    Smyrna, Tennessee
    Thanks for all the replies. I did replace the inverter pump and the AM2 fuse and it's running great now.....except the A/C compressor doesn't seem to be working anymore. not sure what's happened there, a/c was fine before this event.
  13. Jackoar
    22
    Long beach Ca
    Just an update on mine. It took all of 30 minutes to replace the pump. Up and running like new again. Thanks all.
    valde3 and bisco like this.
