06 HV Battery Module Replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dr3wst3r, Jun 17, 2017.
  1. dr3wst3r
    dr3wst3r Junior Member
    22
    Seattle
    I have an 06 Prius that threw the following codes. P3000- Battery Control System, P0A80-Replace Battery Pack, P3021- Block 11 Becomes weak.
    I took out the battery pack and completed a load test using a 12v 55watt bulb. I am trying to figure out what the best next step it. I have access to a hybrid Automotive Grid charger and have already installed the wiring harness. I am planning to replace any bad modules and then discharge, charge and balance using the Grid charger.
    Can someone please take a look and help me to figure out which modules need to be replaced? Also, the one replacement module i do have has the same drop that my "Bad" Modules had (7.6). Inside of the testing document the modules are numbered incorrectly for a gen. two. In mine, the modules are numbered from the drivers side to the Passenger.
    batteries /resting 2 min load /drop
    1/ 7.62/ 7.05 /0.57
    2 / 7.74 / 7.1 / 0.64
    3 / 7.79 / 7.15 / 0.64
    4 / 7.78 / 7.13 / 0.65
    5 / 7.76 / 7.15 / 0.61
    6 / 7.8 / 7.18 / 0.62
    7 / 7.77 / 6.99 / 0.78
    8 / 6.54 / 5.75 / 0.79
    9 / 7.79 / 7.18 / 0.61
    10 / 7.79 / 7.15 / 0.64
    11 / 7.78/ 7.1/ 0.68
    12 / 7.77 / 7.15 / 0.62
    13 / 7.76 / 7.16 / 0.6
    14 / 7.76 / 7.1 / 0.66
    15 / 7.77 / 7.15 / 0.62
    16 / 7.78 / 7.11 / 0.67
    17 / 7.76 / 7.14 / 0.62
    18 / 7.78 / 7.13 / 0.65
    19 / 7.77 / 7.15 / 0.62
    20 / 7.78 / 7.11 / 0.67
    21 / 7.77 / 7 / 0.77
    22 / 7.78 / 6.95 / 0.83
    23 / 7.76 / 7.16 / 0.6
    24 / 7.77 / 7.13 / 0.64
    25 / 7.76 / 7.16 / 0.6
    26 / 7.76 / 7.15 / 0.61
    27 / 7.77 / 7.1 / 0.67
    28 / 7.55 / 6.96 / 0.59
    new battery 7.51 6.75 0.76
    Thanks for the help
  2. JC91006
    16,482
    8,400
    Change out module 8, charge and balance with a grid charger.
    While the battery is taken apart, you may want to clean up the copper bus bars. Remove them and soak them in some vinegar overnight then reinstall
    #2 JC91006, Jun 17, 2017
    jeff652 and Raytheeagle like this.
  3. dr3wst3r
    22
    Seattle
    So just to help me understand, is the main reason to just replace mod 8 the low voltage? Also, if i use the "New" battery that has a 7.5V will that be fine?
    Thanks
  4. JC91006
    16,482
    8,400
    Yes and yes
    jeff652 likes this.
  5. dolj
    dolj Senior Member
    7,657
    3,868
    Wellington, New Zealand
    I would charge up the battery until the voltage stops rising and then continue to charge for another 4-6 hours before doing any discharges.
    I find it interesting that block 4 is showing similar voltage drop to block 11. Also of interest is the symmetry, in that block 4 and block 11 are the 7th and 8th modules from their respective ends. to me I would say block 4 (modules 21 & 22 as marked) is going the same way as block 11, so if it were me, I'd get three more modules that have similar characteristics as your current modules and change out 7, 8, 21 & 22, seeing as you have the battery out an dismantled. My feeling is if you don't, you will get to do this all over again, very soon.
    I would observe (using Techstream or Torque Pro) how the modules are behaving once I had it back together and the car running. It would be easy to see if the "new" modules are working well with the "old" ones.
    It is not just voltage that is important, it it the rate of voltage drop/increase (in relation to its peers) when the modules are discharged and charged.
    #5 dolj, Jun 17, 2017
  6. JC91006
    16,482
    8,400
    Lowered capacity in block 11 can be fixed with the discharges. You can test again after reconditioning and balancing the pack.
    Putting in new unknown capacity modules can be worse than reconditioning the existing ones.
  7. dolj
    dolj Senior Member
    7,657
    3,868
    Agree 100% which is why I said:
    JC91006 likes this.
  8. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    I agree with @JC91006 and @dolj. Charge first before discharging per the Prolong instructions. And do that before replacing parts. Then replace parts if you still need to.
    But a good cleaning while your in there is also a good thing. Also, take a look at the crimp connectors for the communications wires as well as the power cables.
    Robert Holt and JC91006 like this.
  9. dr3wst3r
    22
    Seattle
    So what do people suggest is the best way to assess and get matching modules? Most online retailers simply state the voltage
    Paul Schenck likes this.
  10. dolj
    dolj Senior Member
    7,657
    3,868
    Charge them so the resting voltage is the same as the average of your good modules and then apply the same load test. Don't use any that have a significant variation, either significantly higher or lower the the rest. It doesn't necessarily mean you need to bin them, but you need similar characteristics if they are to work well with the others. A better module can be as bad as a worse module when put in with existing modules.
  11. TMR-JWAP
    TMR-JWAP Senior Member
    6,229
    5,916
    Columbia, SC
    dr3, Here is the deal. Out of those 28 modules in your ORIGINAL 2006 battery pack, #8 has failed. It's done, gone, over, get rid of it. In my experience of disassembling/testing/rebuilding batteries, the remaining 27 modules will vary in capacity from ~1500mah to 6000mah. That means that even though they are at a similar voltage, some capacities will be as low as 1500, and some may be as high as 6000. There's no way to tell which module has what capacity, unless you test cycle each one individually. That means you would need to buy additional test equipment=$$$. My testing has also showed that this variance (1500-6000) can be tightened up significantly (to withing a few hundred mah) by discharge/charge cycling the modules several times. The grid charge/discharge accomplishes the same thing, it just does all modules at the same time instead of individually. The situation you are in right now, following module 8 replacement, is ideal for the grid charge technique.
  12. ericbecky
    ericbecky Hybrid Battery Hero
    4,371
    3,220
    Madison, Wisconsin
    Unfortunately there isn't a "standard" for assessing modules.
    And the ring lies the problem.
    I use my own method for the ones I sell but it may not match the customer's methods. I may use settings for charge/discharge but they may be doing something completely different.
    There really is no good way to make sure that you get modules that are as equally degraded as the ones in a failing pack. Unless of course you use the exact same methods. Even them sometimes equipment can have variability, so it would be even better if they were tested using the same equipment. But that is not reality.
    Could a standard be created for equipment, methods, etc. I suppose. But getting suppliers to conform to it is unlikely. And if they have to do testing to match a customer's settings/methods, that could increase the cost of modules beyond what people will pay.
    Even when I and other supporters of this forum sell tested modules for $50 including shipping, many people balk and instead choose go to random people on ebay since the cost is less. (sometimes the even choose to buy from sources that have already been confirmed to rip off other members of the forum with poor workmanship.) But life is about choice and that simply is what it is.
    As much as possible, I prefer to sell customers sets of modules that all come from the same pack. This can help limit the variability.
    SFO, Robert Holt and jeff652 like this.
  13. TMR-JWAP
    6,229
    5,916
    Columbia, SC
    Here is a spreadsheet from a 2007 HV battery I'm currently cycling. Column 'a' is the first measured discharge. This is straight from the original car, and shows what energy that module contained. It's easy to see module 14 is the problem. Using only that information, it would be easy to say that module 2 and 16 should also be replaced. BUT, column 'b' shows the capacities following several deep cycles. #16 doesn't look so bad anymore, does it? Modules 2, 25 and 27 are currently cycling, so those values are not available yet.
    ..........a...........b
    1.....4438.....6397
    2.....1635
    3.....3562.....6386
    4.....3918.....6298
    5.....3758.....6496
    6.....2912.....6412
    7.....3909.....6481
    8.....3621.....6414
    9.....3400.....6520
    10...1910.....6424
    11...4009.....6392
    12...3540.....6536
    13...3837.....6437
    14.....289.....BAD
    15...4164.....6383
    16...1479.....6399
    17...3379.....6469
    18...3769.....6392
    19...2910.....6399
    20...3990.....6438
    21...2190.....6439
    22...3552.....6343
    23...3644.....6535
    24...3822.....6447
    25...3199
    26...2755.....6325
    27...3008
    28...4205.....6339
    #13 TMR-JWAP, Jun 17, 2017
    JC91006 likes this.
  14. ericbecky
    4,371
    3,220
    Madison, Wisconsin
    The best you can do is compare them to each other. So they are similar-ish for now. Would be even better to let it sit for a week (or even a few weeks) to see how much they self discharge.
    They look decent enough for now, but they will likely get out of whack again in the future if you don't implement some type of regular maintenance.
    Also since you are going to installing modules from a different pack, you will be adding in even more variability that you will need to tamp down over time.
    You are officially off and running on your exciting and never-ending game of Whack-a-mole.
    Continue to play it as long as you are having fun and have the time the free time to devote to it.
    Robert Holt likes this.
  15. ericbecky
    4,371
    3,220
    Madison, Wisconsin
    And if you are willing to share ...
    - Brand/model of module charger/discharger you are using.
    - charge setting (amps)
    - discharge setting (amps, minimum voltage)
    - rest period (minutes)
    - Active cooling during process (y/n)
    - number of cycles
    Raytheeagle likes this.
  16. dr3wst3r
    22
    Seattle
    Two Questions
    Any suggestions on the best way to clean the copper battery connectors. I think I was leaning toward a vinegar salt paste and then a Bakingsoda water bath to stop the chemical reaction, then finally I am planning on using some electricians grease.
    Second, what is the best way to take out a middle pack. I saw some videos that loosened the packs and then slid out the bad module but i am having some troubles.
    Thanks
  17. stockdaddy
    stockdaddy Member
    208
    56
    Missouri
    steel wool will clean it also.
  18. dr3wst3r
    22
    Seattle
    Thanks again for all the help. I am about to reassemble the set up. Copper bars are looking good but one minor snafu. I threw the screws in the same vinegar/salt solution with out fully thinking, bad idea. They are now spotty with black. I rinsed them in the baking soda and water mimix and them cleaned them off with a rag. Here is what they look like do you think there could be any adverse reaction to installing these.
    IMG_20170618_191333.jpg IMG_20170618_191231.jpg IMG_20170618_191333.jpg IMG_20170618_191231.jpg
  19. TMR-JWAP
    6,229
    5,916
    Columbia, SC
    It looks like some of the zinc plating is gone, but in the big scheme of things, they'll work fine. You can always check it out in 6 months to see if corrosion buildup is occurring. Be careful torquing them as to not snap a stud. That tends to make the job a little harder. Personally, I use a single purpose 1/4 inch drive torque wrench that's been calibrated to release at 48 INCH lb. The recommended torque value for that size fastener is 41 inch lb lubed and 54 inch lb dry. 48 puts it on the safe side of 54 and about dead center of the 2 specs. .
    JC91006 likes this.
  20. JC91006
    16,482
    8,400
    if you haven't assembled the pack yet, maybe you can buy some other terminal nuts? there should be members here with plenty of those available.
