06 keeps going to neutral
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by larry9901, Aug 5, 2011.
  1. larry9901
    larry9901 Junior Member
    44
    michigan
    Hey guys,
    I just received a phone call from my wife stating her prius automatically goes to neutral.
    She mentioned there were not any odd noises. Just that once in drive it automatically goes to neutral.
    The car is now parked in a lot until I go and take a look.
    Has anyone know of or had this issue?
    Car has 60,000 miles and prior to this there has not been any indications of any issues.
    thanks
    larry
    thanks,
    larry
  2. Patrick Wong
    18,200
    6,492
    Hi Larry,
    I suggest that you ask your wife to try holding the shift lever in D, as a workaround. For example, she might hang her purse on the shift lever to keep it in D.
    If that works, then you don't have to arrange to pick her up, etc.
  3. larry9901
    44
    michigan
    I will give her that direction once she is finished with her nightly activities.
    Then what?
    Do you have any links or sources to what may have failed and where and howto fix?
    This is something I would do as I don't like going to the stealership
