06 p3190 p0a0f
Discussion in 'Gen 2 Prius Main Forum' started by Njapilot, May 12, 2020.
  1. Njapilot
    Njapilot Junior Member
    29
    DFW
    So 2nd time car went into limp mode then, refused to restart the ice. Clean MAF sensor, car burns oils, so I check it daily. never let the car go below 3 bars of gas. 290xxx miles.
    This last time it did it to me, I put on a jump starter battery pack on the 12v battery and the car fired right back up.
    What is weird is I put a volt meter on the battery and it reads 12.6, I go into service check page (flipping the light switch on and off) it reads 11.6.
    any help would be great.
  2. Njapilot
    29
    DFW
    btw the 12v is a yellowtop, that is about a year old, and the main battery pack was replaced with one of the newpriusbatterys cylinder battery packs. It was running great until I ran into this.
    49,377
    the delta is without and with load. is there inverter fluid movement?
  4. Njapilot
    29
    DFW
    Yes there is movement.
  5. bisco
    49,377
    if the jump start worked, there has to be something wrong with the battery?
  6. Njapilot
    29
    DFW
    Did the inverter pump. Last year as well.
  7. Njapilot
    29
    DFW
    But the battery is reading 12.6 with nothing on and it reads 14.1 when idling. So maybe the battery cables? It's receiving a charge when driving.
  8. bisco
    49,377
    i would take it to an auto parts store for a free load test. worth checking the cables for cleanliness and tightness, especially neg to ground point.
    check the voltage at the front jump point with the car off
  9. Njapilot
    29
    DFW
    checked all cables for tightness. Didn't check the front jump points. Good idea.
  10. Njapilot
    29
    DFW
    just checked the jump on points. 12.7 volts and 14.1 while running
  11. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    Have you cleaned the maf sensor and throttle body?
    How much gas is in your Prius?
  12. Njapilot
    29
    DFW
    On a full tank. Clean mass air sensor the first time it stranded me.
