'06 Prius battery upgrade to LTO 55Ah cells
Discussion in 'Gen 2 Prius Accessories & Modifications' started by T1 Terry, Jul 24, 2022.
  1. T1 Terry
    T1 Terry Active Member
    929
    486
    I bought my '06 Prius from Jason from Oz a few yrs back. It had extensive modifications already, including the Enginer plug in battery set up, 74 x 40Ah LFP cells that topped up the NiMh battery as required until fully discharged.
    After an unfortunate traction battery fire that was of my own making, the vehicle was an insurance financial write off and I bought the vehicle back from them.
    I've finally started the Yinlong 55Ah cylindrical cell battery upgrade. The objective is the build a high capacity traction battery that will work with the original Prius equipment ..... time will tell if I'm dream or not .....
    The dry powder from the fire extinguishers doesn't do the average vacuum cleaner a lot of good, even the workshop H/Duty units had a hard time with it.
    This was the first layout idea, all 84 cells would fit and there would now be some room above the battery to carry the spare wheel, jack and charging cables, that was all lost with the Enginer kit battery.
    The downside of this arrangement was only utilising part of the spare wheel well and only around 36 cells over the rear axle, the rest behind the axle.
    I know this is better weight distribution than the Enginer set up, but I wanted more :lol:
    This arrangement puts 48 of the cells standing up over the rear axle and the remaining 40 cells will be mounted in two layers 2S10P in a box where the spare wheel well was originally. This will give me the whole floor available to build a box to carry the spare tyre, jack, charging cables and a lot of other gear while still having a flat floor at the rear.
    T1 Terry
    OBJUAN, SFO and Another like this.
  2. T1 Terry
    929
    486
    Fortunately my maths isn't all it could be, if I fit 40 cells under the floor I only need to stand 44 cells up where the original traction battery was .... I say fortunately, because I realised unless I mount the pack a bit more towards the rear of the vehicle, the seats would hit when opened up .... Removing 2 cells from each side gives me plenty of room and still the required 84 cells.
    T1 Terry
    ColoradoCrow and OBJUAN like this.
  3. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    Good work, keep us updated. Prius owners need more options.
  4. T1 Terry
    929
    486
    Thank you, at least this means someone has read it :lol:
    T1 Terry
  5. T1 Terry
    929
    486
    This was yesterdays effort, sure doesn't look much for a whole day, but I had already made the base for the 48 cell, so I had to modify it .... that at least accounts for a bit of the time :rolleyes:
    T1 Terry
    ColoradoCrow, Another and OBJUAN like this.
  6. bisco
    51,901
    slow and steady, safety first. all the best!
    ANDRAS RIMELY likes this.
  7. OBJUAN
    OBJUAN Member
    165
    78
    canada
    i'll keep an eye on your progress, good luck:eek:)
    ColoradoCrow likes this.
  8. T1 Terry
    929
    486
    I've started welding the aluminium tread plate box for the top battery pack ..... mig welding aluminium isn't like riding a bike, it doesn't take long to loose any finesse I might have had, then again maybe my memory is painting a better picture of what my welding looked like in the past :lol: Wish I could TIG weld aluminium, but I shake so bad I wouldn't be able to keep the tip out of the weld pool ....
    T1 Terry
    ANDRAS RIMELY, OBJUAN and bisco like this.
  9. T1 Terry
    929
    486
    I'm about half way through welding up the top battery box. Haven't decided if it will be the base with a lid, or the cover with the cell mounted to the base and the cover bolting down onto the base.
    I'm certainly not going to post any of my welding effort photos, I'm even thinking of locking the doors so no one can come and and see any of them before I can clean them up a lot with the grinder. The floor around the bench looks like it's been snowing aluminium .... if my welding is going to improve with practice ... it seems I need a lot more practice :oops:
    Between aluminium pigeon droppings attempts, I've been trying to figure out how to do the cell links, get enough spacing so to terminals don't come into contact with the aluminium box and not suffer any damage from bouncing around on the base of the box. Looks like lots of stainless all thread 5mm rods required, just gotta figure out how to anchor them to the base because I don't want to drill holes ..... at some stage I want to try flooding the box with "E fluid" to act as a coolant while protecting the connections from the air to stop oxidisation ..... my crap welding is requiring a lot of rewelding in an attempt to make it oil tight .... even harder than water tight because oil will creep through the smallest pin prick :whistle:
    T1 Terry
    T1 Terry
  10. OBJUAN
    OBJUAN Member
    165
    78
    canada
    Wow, the effort. Is it your intent to make it a PEV?
    Battery Hookup had posted LFP A123 32113 EV packs arranged in 10s2p for $100.
    The cell specs were amazing. 7 units would do the job but have to make a custom box.
    Then they pulled the listing. Does not say sold out, just gone.:O)
    I replaced another set of 5 headways in the pack. So far it is staying balanced within 160mv
    at 5 blue bars and up. Still don't trust it for long trips, around town has been fine.
    #10 OBJUAN, Jul 31, 2022
  11. Another
    1,819
    517
    Naples, Florida
    Whatever the reason, we need more entrepreneurs like @T1 Terry who want to add lithium batteries to Prius’s. The fact that the Prius’s BMS seems so accommodating to foreign batteries is a great thing as well.
    Prius Rising likes this.
  12. T1 Terry
    929
    486
    Yes, a hybrid PEV that can charge from the fast charger networks being rolled out and the ultimate aim is to be able to use the DC ultra-fast chargers.
    Once I get that all working, the next aim is to replace the ICE with an electric motor to simulate the ICE spinning the planetary set so the 80km/h (50 mph) limit the limp home mode has can be eliminated because MG1 will no longer go into over speed.
    The other aim is to increase the regen capacity so the traction battery doesn't reach its max capacity on the run down a long hill. Maybe by incorporating regen on the electric motor that will replace the ICE, the B mode can be used for added regen braking where needed.
    The fact an electric motor uses less current when spinning fast than an ICE uses fuel, that "scream my tits off" mode the ICE goes into when climbing a hill will no longer be a mode to try and avoid.
    Lots of plans for the extended project, but just at the moment, simply building the first battery box is eating up all my spare time ..... partly because my welding requires better eye sight than I seem to have at the moment .... once the cataracts are done, that should improve.
    T1 Terry
    ColoradoCrow and ANDRAS RIMELY like this.
  13. OBJUAN
    OBJUAN Member
    165
    78
    canada
    Ok, wondered how you'd get by the EV mode speed limit.
    Another electric motor, hold the ICE.LoL
    Before the I changed out the last bank of 5 LFP's, I was driving up the mountain to get home and I got the dreaded triangle.
    Beast dropped into limp mode. I was afraid to reset the error with Dr. Prius thinking the ICE might not restart and I'd
    have to call a tow. Could have walked faster on the steep parts. I crawling on the narrow shoulder, hazards flashing
    and annoyed drivers passing by, embarrassing. In the garage, I reset the error, it started ok into ready mode. Next day
    I swapped out that bank. Today, down the mountain, blood test, some shopping for the wife and home. No issues...yet.
    Cheers:eek:)
  14. T1 Terry
    929
    486
    I've read all the posts about how great the LFP cells are, so you must be mistaken :lol: Out of interest, what capacity cells and how long did the last?
    T1 Terry
  15. OBJUAN
    OBJUAN Member
    165
    78
    canada
    Headway 32120 8AH, 75pcs used from batteryhookup. If you recall from my posts, 3 overheated, one vented (immediately at ready on)and one went resistive later. I've been through the 5 spares, plus my neighbour gave me 8 he was experimenting with for a 12V batt. Two of those were leaking. So I have 5 iffy spares that came out of the pack a month ago and one I found out uses a welded nuts inside the positive post that I accidentally knocked loose. It's been a year since I put the pack in. Had it out dozens of times hunting for faulty cell(s) or rebalancing them. It died once as it rolled out the garage onto the driveway. That was the cell that went resistive in February and then limp mode up the mountain last month. Maybe 4000 kms tops on them but no long trips just around town errands.
    Latest project is rehydrating a pack. Throughly clean the negative posts of electrolyte and seal each with silicone. Drilled 1.6mm holes and tapped 2mm SS or nylon screws in each cell. Added ~7ml of potassium hydroxide into each cell. A dry battery weighs about 1030gm, wet about 1080gm. A generous dab of silicone over each screw. Wondering if a drop of silicone oil might loosen the stuck vent valves so they work properly and not push electrolyte out the negative posts... Scrubbed the bus bars with 1/2" deep socket stuffed with plumbers emory cloth. Assembled the compressed battery cartridge and will make a new sense harness with silicone wires and a new battery ECU connector found on aliexpress(white instead of orange). With luck I'll get that in the beast in the next week or so...
    Not as ambitious as your efforts!!! lol
    SFO likes this.
  16. T1 Terry
    929
    486
    I read on another thread from yrs back, that the bloke pressurised the cell through the hole he drilled to re hydrate the battery and it took over 120 psi to get the relief valve to finally vent. After that it was back to 80 psi.
    My plan, that I haven't actually tried yet mind you, was to drill a hole each end of each module and tap it with a 4mm thread. Then, using those irrigation hose fittings, extend the tube on one side to the bottom of the module and the other side just the standard plastic nipple. Glue them in with T Rex adhesive that sticks to everything and creates a very strong bond.
    Next, run a hose from each nipple, the one at the upper level of the module to one tank and the one with the extended piece going to the bottom of the module to a second tank.
    The tank feeding the upper part of the module is mounted slightly higher than the other tank, but the top of the second tank comes about half way up the higher mounted tank.
    Run a balance pipe between the two tank, but high enough up so the rubbish from the modules doesn't enter the balance tube but rather settles on the bottom of the tank.
    Now fill the higher tank with KOH and it will siphon through the modules pushing the excess out the tube in the lower part of the module, flushing out any rubbish.
    Slowly the air in the top of the module will escape back up the inlet hose, being flushed out each time the module pressurises, then the module will refill when the pressure drops.
    This will keep the modules full and end the over pressure problem that causes the leaking terminal posts.
    The alternate version was the very carefully drill a hole in the depression beside the vent tube and tap a ... 6mm I think it was, fitting into the threaded bit and run the tube to a tank full of KOH to allow the trapped air to escape and KOH to refill the module. This idea doesn't flush the rubbish out of the module, but at least it addresses the over pressure and dehydration issues.
    T1 Terry
    EDIT: Just a foot note, if you want to go the drill a hole in the depression method, be very careful how deep you drill, if you go too deep and hit the cell plates the cell shorts out and goodbye module
    #16 T1 Terry, Aug 5, 2022
    SFO likes this.
  17. T1 Terry
    929
    486
    Finally finished welding up the box, went to put it in place and bolt a back seat in to see how it looked ..... that great Aussie-ism. yeah/nah ... too tall so it needed to be leaned backwards to follow the angle of the eat back .... looked ok with the seat up, but when it was laid out flat, too tall to look halfway acceptable .... start again, back to the first idea and see how that looks with the extra cells in the now modified wheel well.
    T1 Terry
    ColoradoCrow, OBJUAN and bisco like this.
  18. turnip73
    turnip73 Junior Member
    Ireland
    Hi T1 Terry,
    Nice project. I've started the other end but with the same goal. Currently leaning towards a BMW hybrid battery pack but will follow your progress closely.
  19. T1 Terry
    929
    486
    Idea number .... lost count actually :lol:
    Pack 1 : 3 cells high x 3 cells long x 2 cells wide to fit between the rear seat mounts and the rear strut pillars.
    Pack 2 : 3 cells high x 2 cells long x 1 cell wide to fit between the rear strut towers
    Pack 3 : Same as pack 1 but mounts behind the rear strut towers.
    That adds up to 42 cells roughly in the same position the original traction pack was, the other 42 cells to go in the hole I made by cutting the wheel well out.
    Here is a photo of pack 1
    How annoying is it when you get the pack together and then realise you don't have any way to connect the sense wire to monitor cell voltage or balancing ...... :whistle:
    It has taken 3 days to get to this point .... at least all the 12mm stainless nuts are welded to make the cell links and the threaded terminals on each cell are cut down to size, so I won't have to repeat those bits :rolleyes: Also, I found a better method for spacers between the cell racking so I don't have to run the 5mm rivnuts and 5mm nut between them on the next assembly ...... but I do have to unscrew them :cry:
    T1 Terry
    ANDRAS RIMELY and turnip73 like this.
  20. Another
    1,819
    517
    Naples, Florida
    This could make a great TV reality show
