06 Prius Engine starts then dies.
Discussion in 'Gen 2 Prius Technical Discussion' started by Randy Jones, Oct 14, 2016.
  1. Randy Jones
    Randy Jones New Member
    Flatwoods, Kentucky
    I have an 06 Prius that has been sitting. After clearing codes, sometimes you can force start it(pressing brake and holding start button). Engine will run for 2-3 seconds then die and won't start back. I was wondering if my HV battery would cause this or the 12v battery. Any suggestions?
    49,434
    i don't think it's either. it can't start with a bad 12v or hv battery. i think you're going to have to read the codes. does it have gas?
  3. Randy Jones
    Flatwoods, Kentucky
    Showing full tank, could it be a false reading on guage?
    Don't really know, I'll try putting gas in it and maybe trying a new 12v battery. Hv cells show 7.2 volts.
    49,434
    again, it can't start with a bad 12v, so that's not it. check all your fluids, especially oil, inverter coolant and pump operation.
  5. bisco
    49,434
    i'm not familiar with the 'forced start' operation, so perhaps i'm missing something there.
  6. Randy Jones
    Flatwoods, Kentucky
    The car won't start by pushing start button one time. I have to hold the button down while pressing the brake. The ready light will flash and you hear the hv solenoid in the back click on and off. Finally the gas engine will start.
  7. CooCooCaChoo
    CooCooCaChoo Senior Member
    901
    503
    Cow-lee-fornia
    2023 Prius
    How long has it been sitting? Could be bad gas if it sits for too long.
  8. usnavystgc
    3,159
    989
    Tucson, AZ
    For one, this is not a forced start, this is a regular start. All Prius require you to push down the brake and hit the start button to start them. So the procedure you're describing is normal starting procedure.
    Second, the car is not starting at all. Remember, the car is started by MG1 which turns the engine for 2-3 seconds at a high RPM (which seems like a start). If the car does not start, it will stop turning it to preserve the charge on the HV battery. Continued attempts to start the car will eventually drain the HV battery. Do not continue to attempt to start this car until you fix the problem.
    As for the problem. Its standard "engine won't start" troubleshooting (fuel, spark, timing, compression, etc).
    bisco and valde3 like this.
  9. bisco
    49,434
    bad gas?
  10. Texas Hybrid Batteries
    Texas Hybrid Batteries Senior Member
    270
    551
    Dallas -Fort Worth
    You most likely need to clean the throttle body and MAF sensor. I can't even count the number of Prius I've seen fail to start because of this issue. Make sure you disconnect the 12 Volt battery for a few minutes before you try a restart.
    Matt
    fotomoto and bisco like this.
  11. ericbecky
    ericbecky Hybrid Battery Hero
    4,371
    3,220
    Madison, Wisconsin
    Using starting fluid may increase your chance of keeping it running at startup once you sort out the other issues.
