06 prius transmission problem? I dont get it
Discussion in 'Gen 2 Prius Technical Discussion' started by kberven65, Aug 23, 2015.
  1. kberven65
    kberven65 New Member
    24
    pierre sd
    Hello everbody new to the prius world! I recently purchased a 06 prius with 185k. Gas engine needed to be replaced so I recently replaced it. Had code of engine failed to start. Now got replacement engine in and has p0300 and p0303 and p0304. Weird thing is new plugs. Swapped coils and injectors with same results. To me it sounds like a racket in the the transmission. The noise is not consistent at all. Very loud and odd. Also inside the carwhen I put it in drive or neutral a warning light comes up and says shift to park batteries wont charge while in neutral. Thanks for any help. Ill post a video shortly that I have
  2. JC91006
    16,475
    8,393
    how did you diagnose the engine was the problem with the "failed to start"? There are many things that can cause thing, unrelated to the engine.
  3. kberven65
    24
    pierre sd
    I work at a oyota dealership. Only thing that made sense. Now I don't know what to think. Also had no oil in it. I have a video. But it wont let me upload it. Would gladly txt it. 6052806390.
  4. kberven65
    24
    pierre sd
    Dont wanna pay to hook it up again.
  5. JC91006
    16,475
    8,393
    The service department can not help out a fellow employee?
  6. kberven65
    24
    pierre sd
    They will but we have one toyota tech and hes really busy. And towing is another thing. Figured prius chat would be good help. Since ive gotten alot of info from here
  7. kberven65
    24
    pierre sd
    B be fore engine sswap I had red triangle. With failed to strt. But with other engine has those other codes stated. I get red triangle in drive and neutral but still moves. Display says shift to park batteries wont charge in neutral
  8. JC91006
    16,475
    8,393
    It would literally take a tech less than 5 minutes to diagnose your car with a proper code reader. If you can get the codes, we may be able to help. Without those codes and all the issues you are describing, it would be very difficult to pinpoint your problem.
    For all we know, the engine replacement might not even be necessary. No start issues usually does not mean replace engine.
  9. kberven65
    24
    pierre sd
    P0300 p0303 p0304. will a regular code reader not get all the codes?
  10. kberven65
    24
    pierre sd
    I have a video of exactly what it sounds.
  11. JC91006
    16,475
    8,393
    Post on YouTube and link
  12. kberven65
    24
    pierre sd
  13. JC91006
    16,475
    8,393
    that's the old engine right?
  14. kberven65
    24
    pierre sd
    No its the new one. Ran flawlessly for two hours prior. Sounds like electric motor is trying to engage
  15. JC91006
    16,475
    8,393
    did you use OEM Denso or NGK plugs? Not sure what would cause a good running engine to misfire like that after 2 hours. Unless it overheated
  16. kberven65
    24
    pierre sd
    Oem denso. After it started this. After its done with the first run. When it goes quiet I can push the accelerator down and engine sounds normal. Its always when it starts on its own
  17. kberven65
    24
    pierre sd
    Anymore input. Will a regular obd2 code reader pick up other codes for tranny?
  18. bisco
    49,377
    you can buy mini vci for $25. if you have an old laptop.
  19. dat2109
    dat2109 Junior Member
    26
    Carolinas
    Any ole code reader can read those misfire codes. And it does sound like a prius misfire to me.
  20. Britprius
    Britprius Senior Member
    5,194
    1,914
    Herefordshire England
    As Bisco correctly informed you the VCI is the way to go giving dealer level of functionality at very low cost. It will read all!!! Toyota, Lexus, and Scion codes as well as performing tasks such as brake bleeding, and keyfob programming. If you work on a Prius in my opinion this is a must have. In fact I will modify that statement with if you own a Prius you should have the VCI.
    I am not in any way connected with the sale or manufacture of any type of code reader.
    John
    #20 Britprius, Aug 25, 2015
