06' Tire Pressure Monitoring System
Discussion in 'Gen 2 Prius Main Forum' started by Paradox, Nov 29, 2005.
  1. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Before I get a "oh, search, this was posted already" reply I do read avidly here and I cannot recall seeing pics or a description about this: On the new 06' Prius, where are the alert indicator's showing if a tire gets low? Does it say exactly which tire, is there a seperate alert for each tire etc? Thanks in advance :)
  2. RonM
    RonM New Member
    72
    From the '06 Owner's Manual (p. 131):
    "(l) Low Tire Pressure Warning Light
    This light comes on when the “IG- ONâ€
    mode is enabled. If the tire pressure
    warning system works properly and tire
    inflation pressure is appropriate, the light
    goes off after a few seconds.
    This light comes on or flashes in the following
    cases when the “IG- ON†mode is
    enabled.
    o When the low tire inflation pressure
    is detected while driving...
    If any tire has low inflation pressure,
    the light comes on.
    The light goes off after the tire inflation
    pressure is adjusted to a specified level.
    o When initializing the system...
    If initialization is completed, the light
    blinks three times.
    o When the system malfunctions...
    If the system malfunctions, the light
    blinks.
    Although it is no problem to continue
    driving, have your vehicle checked by
    your Toyota dealer as soon as possible."
    I have also attached a picture from the manual showing the actual icon that is displayed on the screen (hard to see, looks like a cross-section view of a deflated tire with an exclamation mark in the middle.
    From the tech manual, the tire pressure is determine via individual pressure sensors in the wheel that wirelessly talk to an ECU (as opposed to the less-accurate method that uses wheel rotation measurements from the ABS, etc. system to determine a wheel may be low).
    Open questions (I have not looked in the tech manuals with enough detail to see whether these are answered there):
    1) What's the threshold at which a tire is considered under-inflated?
    2) Is that threshold relative or absolute (in other words, if someone inflates their tires to 40-42 PSI, will the gauge come on at, say, 5% below this value, or at a set PSI, like 25-30 PSI, based on the factory tire inflation recommendations?
    Note that there is a reset button for reinitialization of the tire pressure monitoring system (presumably after tires are properly inflated?). Its under the steering wheel next to the SKS cut-off switch. Presumably, this implies the answer to #2 is that the system is relative, and thus needs to know when you've reinflated all tires to the proper level. If it were absolute, then I don't understand the reason for the reset button, unless it allows you to set the appropriate tire inflation value, like if you want to inflate up to 40+ PSI on the OEMs, or if your replacement tires require a different inflation pressure.
  3. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Thank you very much for the reply and the image as well, I was hoping to get an idea of what the indicator light looked like.
    I hope your idea is right that you can 'reset' the system once you have inflated your tires to a pressure you like. I tend to run a few psi over what the book says as well, in most my cars. Again, Thanks.
  4. Tideland Prius
    16,492
    If I'm not mistaken, you set the level yourself. Just put the tyres to the desired pressure and press the SET button. I'm sure the owner's manual will say something like that. That's what the salesman told me and I assume that the salesman will always be slightly inaccurate until proven otherwise.
