06 vs 08 mpg?
Discussion in 'Gen 2 Prius Fuel Economy' started by jamiesgarage, Dec 19, 2012.
  1. jamiesgarage
    jamiesgarage New Member
    im looking into buying a used prius and have been been looking at many online. ive noticed that mileage advertised for the '05 and '06s that ive looked at is 60 hw and 51 ct but the '08 and '09s is in the 41-48 mpg range. why is that? is there really that much difference between the model years?
  2. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    No. There is no difference in terms of MPG capability. In 2008 the EPA changed their testing procedures and it dropped all hybrids down from the prior EPA estimates. So the EPA estimates for the 2008-2009 Prius are the same for the 2004-2007 Prius. The cars are identical in their capabilities and averages.
  3. sidecar
    sidecar Member
    342
    44
    Australia
    I dont know about you guys but the EPA numbers seem less than generous to me.
    I consistently defeat their rating summer/winter
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Are you using miles per Imperial gallon or miles per (smaller) US gallon? We don't use Imperial gallons here.
  5. sidecar
    sidecar Member
    342
    44
    Australia
    Usually I convert back and forth to and from US
    sometimes reviews use EPA stats here in Au. but reporting can be a bit sketchy and uneven.
    I tend to look at US figures to compare.
    this is a great tool for conversions
    mileage converter - MetroMPG.com
  6. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    I use Google as my calculator.
    Example, Google for: 46 miles per us gallon in liters per 100 km
  7. sidecar
    sidecar Member
    342
    44
    Australia
    yeah that works
    for the first time ever I got to 4.0L/100Km on my usual 150km weekend jaunt,
    a curvy up and downhill trip, mostly at speed 80-100KmPH, with few stops.
    I'm no youngster so I still remember when we had Imp MPG figures,
    and like to refer to that to scale things against my reality
    58.8 US MPG, 70.62 Imp MPG
  8. uart
    uart Senior Member
    4,215
    1,201
    Australia
    I hear you sidecar, I've noticed exactly the same thing. I think the reason that many of us so easily exceed EPA is that the Prius responds so well "hypermiling" (even mild hypermiling) techniques.
    My other car is a Mazda 2 that gets about 6.7 L/100k if I drive it normally. If I hypermile the crap out of it then that only drops to about 6.3 L/100k. So only about a 6% improvement.
    With the Prius on the other hand it's more like 4.6 L/100k with normal driving, dropping to about 3.9 or 4.0 L/100k with a bit of hypermiling. So a much larger 15 to 18% improvement here.
  9. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    There are some other fun conversions w/using Google as a calculator like these:
    10000 furlongs per fortnight in mph
    45 mpg in teaspoons per mile
