'07 connector to headlight melted
Discussion in 'Gen 2 Prius Technical Discussion' started by eharcour, Mar 17, 2013.
  1. eharcour
    eharcour Junior Member
    My headlight went out the other day, so I bought a new bulb & replaced it. When I went to plug the connector into the back of the bulb though, I noticed it was melted and had black edges. With the new bulb, the light still doesn't work. I checked the fuse and it's fine. Has anyone else experienced this? What's the solution, and how much did it cost you? Thanks!
  2. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
  3. howardbc
    howardbc Member
    154
    Scottsdale, AZ
    Hi. I hope you are aware that Toyota knew it had a problem with the bulbs in the headlights of certain years of Prius. There was/is a recall. Make sure you check it out. Not sure about the 2007 but I have a 2008 and it was covered under the recall and they replaced both bulbs at no charge. I recommend that you use PriusChat often. It has saved me a lot of money plus been very informative. Good luck.
