07 engine and trans replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Priusstich, Nov 6, 2024.
  1. Priusstich
    Priusstich Junior Member
    17
    Wisconsin
    Good morning peeps. haven't posted in awhile. Have an 04 engine and trans together (lower mileage). possible to install together ? the hi voltage wires were cut on donor engine. are those a pain to switch ?
    my 07 has rod knock and 270K
    anything to look for ?. check ohms on mg1-mg2 before install.
  2. Tombukt2
    Tombukt2 Senior Member
    12,046
    2,132
    Durham NC
    Yeah I've got an '04 '05 sitting here too You should be you have the engine completely out of the car with the transmission still bolted to it just sitting there You should be able to just undo the covers and take the wires loose at their proper terminations I think they're 10 mm nuts I have to go out and look but it's right around the corner here on the property and you should be able to pick up the whole assembly and set it right in your '07 without any ado I do believe I don't see why not I own both here I haven't done an engine swap from an '04 to a '06 to '09 type car but it should be pretty much Jermaine no problem. Anythings that are different will be easily moved over or what have you and that would be I don't even know what I don't think anything you'll be using your exhaust system and all that on the car so that all stays I think it'll be a direct drop in and bolt up the motor mounts and swing your exhaust manifold or down pipe up and bolt that stuff in and I feel it with coolant and go I'd be very surprised if it wasn't just like that
