07 gray prius issues
Discussion in 'Gen 2 Prius Technical Discussion' started by daveyboy, Dec 20, 2018.
  1. daveyboy
    daveyboy Junior Member
    62
    nj
    So the other day out of the blue the soc drops to purple and then I pulled over.
    2 minutes later start up and away I go on gas, the soc climbs all seems ok just odd.
    I decide to have dealer look at it and they report a timing chain issue and not worth fixing.
    Also they say the 12v battery is in need of replacing.
    Anyone seen a 07 with 150k have the timing chain cause trouble?
    thank you fellow EV'ers.
    david
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    I find it difficult to believe your car would be driving even halfway decently if it truly had a TC problem..........maybe they think it's supposed to be Otto cycle instead of Atkinson
    daveyboy likes this.
  3. daveyboy
    62
    nj
    I thought the same
  4. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    Did the engine stall and that’s why the battery drained?
  5. bisco
    51,140
    i don't understand. you pulled over just because the icon dropped to purple? or was there a trouble light on?
  6. daveyboy
    62
    nj
    It went purple and the car stopped moving i feel like whatever has the engine cycle on to keep the soc up wasnt working
  7. bisco
    51,140
    did the dealer check for codes?
    how many miles on her?
  8. daveyboy
    62
    nj
    Yes they did and said dont put a dime in to fixing it.
    I can post up codes tomorrow when i went to pick it up today they said they couldnt start it.
  9. bisco
    51,140
  10. daveyboy
    62
    nj
  11. Skibob
    2,912
    1,502
    Northern California
    First post says 150k
  12. bisco
    51,140
    not bad. might be worth repairing, depending on what is wrong.
    look around for decent non dealer mechanics in your area.
  13. daveyboy
    62
    nj
    I am hoping they wouldnt mislead me lol and its just symptomatic of a weak 12 v battery. The hv battery is new
  14. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    A timing chain and state of charge of the hv battery are not connected;).
    I’d get a second opinion (y).
  15. Skibob
    2,912
    1,502
    Northern California
    They are if the engine died and he drove on the battery. :whistle:
  16. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    But then it fired up and he went in his way;).
    More info required from te op like codes and quotes from the dealer (y).
  17. Skibob
    2,912
    1,502
    Northern California
    True but he said he pulled over when he saw the purple bars. Stopped in time?
  18. daveyboy
    62
    nj
    Ill post up dealer info tomorrow when i pick it up
    bisco and Raytheeagle like this.
  19. Skibob
    2,912
    1,502
    Northern California
    We’re they able to get it started?
