07 prius headlights adjustment
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by KH.T, Nov 23, 2017.
  1. KH.T
    KH.T New Member
    Kennewick, WA
    Hi everyone, is there any way to adjust headlight's high/low beam on the 07 prius, mine are really out of adjustment and weak after the accident on the driver side. They looke in good shape from outside and inside but not sure if there is an electrical problem.
    Thanks.
    Khalid.
  2. jerrymildred
    jerrymildred Senior Member
    11,511
    14,112
    Tampa, FL
    My '05 had self leveling lights. There's a sensor in the back to the left of the spare tire. It could be related to that. Or it might be that the replacement housing wasn't properly installed if it's just the driver's side with the problem. And, if they are HID lights, it's possible to install the lamps so they are not seated right and that will throw off the beam.
