07 Prius side view mirror replacement
Discussion in 'Gen 2 Prius Main Forum' started by bill phillips, May 11, 2013.
  1. bill phillips
    bill phillips New Member
    Hi. Backed into a tree with driver side view mirror. tree is fine and unharmed. So I have the replacement mirror, removed the old mirror and attached the replacement. My issue is the old mirror has 5 wire , red-purple-brown-black-black. Replacement has 3 wire, red-purple-brown. And the connector is a different configuration. My thought is to #1. splice new pig tail to old pig tail- red to red, purple to purple, brown to brown. #2. tape off the two black wires ( which I'm assuming may be the heated feature). Thank you Thank you for your help. Bill
  2. Britprius
    Britprius Senior Member
    5,194
    1,917
    Herefordshire England
    Hello Bill welcome to Prius Chat. Below is the circuit diagram for the mirrors with wire colors shown.
    Hope this helps.
    John (Britprius)
