07-Prius SRS light ON with NO CODES
Discussion in 'Gen 2 Prius Technical Discussion' started by batis, Oct 20, 2013.
  1. batis
    batis Junior Member
    my left roof airbag and driver side seat belt (retractor) were damaged all parts have been replaced but my airbag light still remains on.
    I erased all the DTC codes with my techstream software
    I've driven the car for 400 miles with the light on and no codes.
    Is there another way to erase the airbag light? Do I need to buy a SRS module?
    I would appreciate any feedback ...Thanks in advance
  2. Patrick Wong
    18,200
    6,472
    I suggest you obtain Toyota repair manual at techinfo.toyota.com
    Perhaps wiring harness damage has occurred from the accident. The repair manual provides advice regarding how to check connections to the SRS ECU, see the Diagnostics section regarding DTC B1000.
    It is possible that the 12V power connections to the SRS ECU are at fault. From the manual:
    "When the SRS warning light remains on and the DTC output is the normal system code, a voltage
    source drop is likely to occur. This malfunction is not stored in the memory by the airbag ECU assy.
    If the power source voltage returns to normal, the SRS warning light will automatically go off."
  3. batis
    batis Junior Member
    I've checked the voltage on my battery when the car is off the battery reads 12.4V and when hit the start button for a second time it drops down to 12.1V when I turn on the car the battery jumps to 14.4V
    I was reading that the DTC B1000 means that the SRS ECU needs to be replaced.
    If I were to get the crash data erased (epron chip) from my SRS module will this work for my prius?
    I've sent out srs modules to get repaired mostly Honda's n Acura's and when I get them back
    they are good as new with no SRS lights on.
  4. Britprius
    Britprius Senior Member
    5,194
    1,914
    Herefordshire England
    Yes this does also apply to the Prius, SRS ECU needs to be reset to remove the light.
    This is required if the airbag was deployed, something not clear from your first post only saying "the air bag was damaged".
    Toyota will not perform this service only supplying a new ECU because of safety implications.
    John (Britprius)
    jbmbenjamin likes this.
  5. batis
    batis Junior Member
    I'm sorry for not being clear what I meant by damaged was that roof airbag deployed and my driver seat belt retractor got stuck(tube inflator went off) meaning the belt is no good.
    I'm going to send out my SRS module to have the crash data remove. I'll keep you guys posted on my SRS light.
    I would post pictures but since i'm new to the forum i'm being prevented.
    thanks.
  6. batis
    batis Junior Member
    Update-
    I got my module back this weekend. The crash data was erased and my SRS light is gone.:)
