07 Prius/Strange Dash noises/video
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Scott56, Dec 19, 2017.
  1. Scott56
    Scott56 Junior Member
    40
    28
    Alabama
    I'm trying to figure out what this sound is. The dealership checked the brake actuators shortly after this started and it didn't pull any codes or see a problem.
    52,408
    sounds like the actuator. might not be throwing codes yet.
  3. JC91006
    16,833
    8,603
    It's a soon to fail 3 way coolant valve. It hasn't failed so there's no codes to pull. When if fails, you'll get a check engine light.
    You can check if your coolant at the radiator is full. Then turn on your heater and run it for a few minutes. That usually gets rid of the noise for a day......then rinse and repeat until you replace the valve
  4. Texas Hybrid Batteries
    Texas Hybrid Batteries Senior Member
    271
    563
    Dallas -Fort Worth
    +1. Mine did that for a year before I replaced the valve. Never did throw a code.
  5. Scott56
    40
    28
    Alabama
    Thanks so much for the diagnosis! I just had both coolants changed last year and wished I had the mechanic change out this valve at the same time. I read that it could be a 500 dollar fix at the dealership but I'll just keep hope it doesn't fail anytime soon.
  6. JC91006
    16,833
    8,603
    I believe it's $77 on Amazon for the part. You can buy a set of plastic hose clamps $10 on Amazon. Clamp the hoses so coolant doesn't leak out and change it out. You can watch youtube videos on how to do this. I would say, it would take a regular DIY person about 2 hours to figure everything out. I can do it in about 1 hour (but I've had a few practice runs and I have smallish hands)
    SFO likes this.
  7. Scott56
    40
    28
    Alabama
    I read that the valve has to be clear of any air bubbles that might seep in the valve, like vacuum tight.
  8. JC91006
    16,833
    8,603
    There should not be any air in your coolant loop. The valve is just a bad valve, they stick. Only way to fix them is to replace them.
