07 Prius: Which Direction Does Coolant Flow Through Heater Core?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Mryankovic, Jan 3, 2025.
  1. Mryankovic
    Mryankovic New Member
    WV
    Title pretty much sums it up I have been reading lots of resources online and I have seen the diagrams, but according to a few YouTube videos some of these diagrams are incorrect, I found the heater core Inlet and Outlet but I'm not sure which one is which. I'm assuming the one on the left is the out and the one on the right is the in. Is this correct?
  2. ChapmanF
    17,180
    Follow the hoses. One connects the core to a small electric pump near the firewall, which further connects to a three-way valve. The two branches from the three-way valve connect to the cylinder head and to the thermos. That heater core connection is the one where coolant flows into the heater core.
    The other connects back toward the engine thermostat bypass nipple, on a route where it also has connections to the throttle body and the electric pump next to the thermos. That is the connection for coolant flowing out of the core and back toward the thermostat bypass.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    3,939
    1,900
    NJ-USA
    There's this diagram that shows the coolant hoses.
    Actually, I think that diagram is incorrect, as I would expect coolant to flow out the side nipple on the heater electric pump toward the core. Then flow should be from the core toward the thermostat area on the engine block.
    I guess that "to-from" the heater sounds better than "from-to"?
    #3 mr_guy_mann, Jan 3, 2025
  4. ChapmanF
    17,180
    Yeah, the arrows in that diagram look wrong. Two of 'em, anyway; they got FRONT right.
    At least, it doesn't match another diagram with arrows, in the gen 2 New Car Features manual. That shows, as you'd expect, the "water pump (for heater)" pumping into the heater core, and the return from the core in the hose that returns to the thermostat bypass.
