08 airbag resistor 2ohm 1/4w not working
Discussion in 'Gen 2 Prius Technical Discussion' started by problemchild, Apr 22, 2008.
  1. problemchild
    problemchild New Member
    429
    36
    I have an 08 and tried the airbag block off with a resistor 1/4w 2.2 and 2.0ohm. I even flipped both the resistors around thinking it was backwards. I still have the red airbag error on my dash. I went in and checked the errors on the nav and dont see any.
    Does anyone have any ideas?
  2. Bob64
    1,540
    92
    Virginia
    try putting in orig airbag and seeing if it clears?
  3. richard schumacher
    7,663
    1,038
    United States
    Pardon my ignorance: what are you doing with the airbag?
  4. problemchild
    429
    36
    OK that did it. The stupid loopback on the seatbelt was the issue. Once I plugged in the seatbelt arm and sensor all was good. What a pain. You have a be a Nasa scientist to change seats.
