'08 Dashboard Lights Not Working
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by stepha430, Dec 27, 2015.
  1. stepha430
    stepha430 Junior Member
    My 2008 Prius dashboard lights/indicator lights are not turning on.
    The car seems to turn on fine. It's not the lights - I've turned on the headlights - they turn on. I've tried turning the dimmer on and off and they work for the console lights. (for example "Info")
    Please advise.
  2. JC91006
    16,480
    8,397
    There's an extended warranty on it for 9 years, bring it to your dealer and get the "combination meter" replaced
  3. stepha430
    Should I have it towed to the dealer? Since I have no idea what the dash says?
  4. stepha430
  5. stepha430
    To make sure we're on the same page. This is what my dash looks like on.
  6. bisco
    49,437
    what do you really need? if it drives, drive it to the dealer. don't pass anyone, and you'll be fine
    maybe there's a fuse for the dash display?
    #6 bisco, Dec 27, 2015
  7. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    Stepha, if you can see the turn signal indicator lights that what JC said is correct. I did look at the picture you posted, to me it looks like the combo meter is not working but I also did not see the "Ready" light.
    To clarify this problem, please post whether you can see the turn signal indicator lights on the dash when you turn on the emergency flashers.
    Also, are you having difficulties powering down the Prius?
    #7 dorunron, Dec 27, 2015
  8. andrewclaus
    andrewclaus Active Member
    993
    324
    Golden, CO
    stepha430 likes this.
  9. stepha430
    The turn signals/blinkers work fine. No difficulties with powering off. It's weird.
    Just dropped it off at the dealers. They were aware of the warranty. Though they said rental car was not covered.
    Thanks everyone for your help.
  10. PriusGuyfrom213
    PriusGuyfrom213 New Member
    L.A.
    Just wanted to share. This worked for me.
  11. JC91006
    16,480
    8,397
    Symptom of a low 12v battery? Interesting. That's a new discovery. Maybe I should sell my 2 spares.......
