  1. CrownVicTraitor
    CrownVicTraitor New Member
    Chicagoland
    I
    Hey all, I am sorry if I'm missing where this may have been posted before, I probably could have searched, however I have limited time and need to resolve this immediately.
    Bought a Prius, ran great when I test drove it, not one hiccup. Checked everything.
    Then I got it 40 miles down the road and it started misfiring. Codes are a p2601, and p0301/2. There is a touch of moisture on the oil cap, and a little moisture in the spark plug wells, but that's it. I'm thinking head gasket, and I'm thinking I should swap it... right? Could this be something easier, take less of my time? Could this be foreshadowing and I should just swap the engine? Anyone on here have an engine for cheap?
  2. Tombukt2
    Tombukt2 Senior Member
    8,876
    1,549
    Durham NC
    Clean up the plug Wells first get all the moisture and everything you can cleaned up and see if the misfiring stops. Then check your plugs maybe resistance check them or replace with new and resistance check the new ones to make sure you have the right K ohms.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    3,423
    1,482
    NJ-USA
    P2601 is set when the ECM "sees" something is wrong with the Coolant Heat Storage tank water pump or relay. Short term - ignore this code until you have nothing better to do (or if you need the check engine light to stay off for inspection).
    P0301/302 - lots of things can cause misfires.
    First check that all fluids (oil, coolant - in the radiator, etc) are full.
    Replace the spark plugs with NGK or Denso from a reputable source (ebay and amazon are known to have counterfeits). Consider replacing the ignition coils - again Denso or Toyota from reputable source.
    Any moisture in the plug bores can cause misfire. The hood - cowl seal leaks onto the engine and can cause your problems.
    The early symptoms of a head gasket are misfire on cold start-up that lasts a few seconds along with slow coolant loss.
    Head gasket problems are extremely rare on Gen2 1.5L engines.
  4. CrownVicTraitor
    Chicagoland
    I
    well I had some cheap Oreilly coil packs, 2, so I took cylinder one and two packs off, rolled up paper towels to stick in the bores for drying, a puddle was in cylinder two. Put the new coil packs on and the thing ran fantastic, no more misfire, and the hybrid battery finally charges to green again…
    till about mile 20, misfires are back. I’m getting out now to pull the packs and see if there’s any new moisture. Odd thing is, there was never a smell of coolant… maybe it’s the packs themselves, I have bought packs that were just bad out the box.
  5. CrownVicTraitor
    Chicagoland
    I
    Okay… weird… so I cleared the codes, and then took it for a drive to get new codes, make sure I know what cylinder is missing (before I cleared the codes I got cylinder 3 now as well as a random miss code), and now it’s missing and making the cel flash, but then it goes away and so does the cel… is it supposed to go away like that until a certain mile mark, or what?
  6. CrownVicTraitor
    Chicagoland
    I
    Okay, LOTS of moisture in cylinder two, and some in three. Could this be due to bad spark plug seals at the valve cover?
  7. CrownVicTraitor
    Chicagoland
    I
    It was water. I cannot believe it was that simple. I pulled the coils and blew the wells out with an air compressor, and presto, runs smooth.
  8. Tombukt2
    8,876
    1,549
    Durham NC
    So your wiper tray is in right and your wipers are installed moisture if it gets on top of the valve cover sometimes it can seep through and be riding in that ridge between the spark plug extension and the actual valve cover itself there's a little ridge there and water can sit there when that overfills it'll run down the sides of the extension and sit right down against the spark plug and will cause a misfire and it will be random because it could be a couple cylinders that have just enough moisture to cause a miss but yet don't really wipe out a lot with the towel or something I just use something like moisture remover wire dryer spray whatever and leave the plugs in the coils out for a few minutes while I'm doing other things let everything dry up but water should not be getting in there from the engine there's no water jacket anywhere near the spark plugs so it's generally got to be coming through the seals around the coils usually during the rain or heavy car washing or I don't know what I see more of this in the generation 3 that thing will pick up moisture from zero moisture air it's unbelievable.
