08 prius drivers seat replacement
Discussion in 'Gen 2 Prius Accessories & Modifications' started by grafdl, Aug 20, 2013.
  1. grafdl
    grafdl Junior Member
    Illinois
    Bought a used drivers seat (perfect condition) taken from a totaled prius, to replace my torn seat. Was shown the location of the orange hybrid battery connector and how to remove it, and the location of the small battery, and told to remove either the pos or neg terminal, before disconnecting and removing the old seat (4 bolts and 2 connectors, I think). Is there anything else I should be concerned about, and/or is there a link for these instructions?
  2. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    I think if you remove the 12 volt battery ground, that should ensure the airbags don't deploy.
    That being said, make sure the car is turned off, just check!
    Unplug the seat from the car, remove bolts, swap seat.
    Reassemble in reverse order!
  3. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    748
    Delaware
    um, this is not a mod, but i hope it goes smoothly.
  4. Justdidit
    Justdidit LVNPZEV
    1,880
    709
    75
    Carrollton, Texas
    Four Touring
    Could be if he was upgrading to leather! :)
