08 Prius MFD service check NO GW connection
Discussion in 'Gen 2 Prius Main Forum' started by ColoradoCrow, Nov 9, 2020.
  1. ColoradoCrow
    ColoradoCrow Active Member
    975
    393
    Leawood, KS
    I
    Hi. Where do I start on fixing this problem?
    the MFD doesn’t get data from the engine or temperature from the climate control.
    EMV OK
    Audio HU. NCON but I have an aftermarket unit
    G/W NCON
    under the LAN Monitor sub menu I have
    EMV CHEK
    audio H/U. NCOn
    g/w NCOn
    Where Do I start fixing this problem?
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,256
    5,952
    Columbia, SC
    My first question would be 'when did this problem begin?'
    Did you install the aftermarket audio or a previous owner?
    Did everything work prior to the installation and afterward?
    Was the MFD removed for working on the audio?
    Have you already verified all the connectors supposed to be connected to the MFD actually are connected? It can be easy to miss one, depending on the model.
    Did the audio installation require cutting/splicing of wires or was it all premanufactured pigtails/adapters?
    SFO likes this.
  3. ColoradoCrow
    975
    393
    Leawood, KS
    I
    OK problem solved. My 68 ohm resistor I installed for the Aftermarket radio had a loose connection and fell out when I checked it. I soldered it properly this time. So far everything is Ok including the self check from the MFD unit. So. Be sure to solder and not wrap the wires together like I did the first time. It lasted 6 months. yuck.
